  3. Bad Object Labelling In DLMSDirector 8.0.0.21
Bad object labelling in DLMSDirector 8.0.0.21
By coppice , 22 July, 2016
The attached image is from DLMSDirector 8.0.0.21. You can see that the 6 byte codes for the list of objects are all different, referring to a variety of instantaneous parameters. However, the labels for what these codes mean all say the same thing - "Sum Li Active Power+ (QI+ QIV) Inst. value"
10 years 2 months ago
You are right. There must be issue on description parser. We'll fix this.
I added issue from this: http://www.gurux.fi/node/5523
  • 7095384824
  • koltom
  • palso
  • VigneshwaranC1993
  • Yousef Al-Saye…
