  3. Comunicate Between Two System
comunicate between two system
By sayedali , 28 January, 2016
how can i comunicate between two ARM microcontroller by dlms protocol?
10 years 7 months ago
Another must be a server and anothere client. Client makes connection to the server and if server accepts client, connection is initialized.
Basically you create server that listens some TCP/IP port and then you create client that connects that TCP/IP port.
sayedali
packet data of the dlms protocol include a lot of sections.can you help me how can i make this packet data and introduce sections of packet data.
You can use our DLMS components. You will find them from GitHub:
https://github.com/gurux
DLMS is very complicated protocol. If you are interested all data is described in standards. You can study them. It's not easy to start describe structure of the packet.
sayedali
In reply to comunicate between two system by Kurumi
a few days i worked on your DLMS components from github(c++).but i cant understand how do work codes,when i dont know about dlms architect and protocol.can you help me how can i understand these codes ?
DLMS is VERY complicated protocol. Try to read this first:
http://www.gurux.fi/Gurux.DLMS
Then you can check the standards. We are also selling our consulting services.
So we can also help you if needed.
sayedali
10 years 6 months ago
Hi.i need your help and consulting services.in fact,i should make library based on dlms/cosem protocol.and with this library ,i want to program two arm microcontrollers and comunicate them from dlms/cosem protocol and my physical layer is rs485. i study every page of www.gurux.org website but i can't understand where i am starting!!!!
also i study Excerpt_GB6 and iec62056-21 but i can't result what should i do??
if github code can help me to i solve my problem ,please help to understand github code and library(c++).if not please help me write library code that i solve my problem.
thanks
In reply to comunicate between two system by sayedali
We will help you to solve your problems. DLMS is very complicated protocol.
Please, send email to me. You will found my contact info from here:
http://gurux.fi/AboutUs
  • Ask313
  • EmilioBecerra
  • Kundan Dhande
  • Shah Wali Haidari
  • Olga
