  3. Set Date On Landis E550
Set Date on Landis E550
By jpaa07 , 28 January, 2016
I have a problem, when I set Date of Landis E550 with .Map110 program, the program sends 6 frames, on the third, it sends 8 bytes before the FCS bytes, but I don't know from where they come, if someone Knows from where the 8 bytes come or how can I calculate it, let me know please , Here is the log of the program with the 8 bytes in red.
Thank You!
10 years 9 months ago
It's little bit difficult to say because there is no meter replies.
But you are using High authentication and I believe that that
Write message is used to tell pw to the meter.
High authentication is a problem, because DLMS specification does not specify details
of the HLS mechanism. So each manufacturer have own implementation. :-)
You can read more here:
