I implemented a profile generic to save microcontroller's unique identifier, composed by 3 objects of type Data. When I try to read that profile from GXDLMSDirector I get the following error: "Number of columns does not match". What does this problem mean? Where could possibly the problem be?
Because you didn't add the hex trace I can't verify this, but I believe that amount of the capture objects is different than the number of columns in the buffer data.
the problem is solved. Sorry for the late reply. I have another question that I will post in another topic.
Thanks.
