  3. Different Response On DLMSDirector & Android App
Different Response on DLMSDirector & Android App
By p1j , 3 November, 2022
Just starting with a dive in DLMS world, and its just the beginning.. Trying connecting to a Common meter (Genus Power) using the common optical probe (FT232) with the android based app (using .net & Xamarin) and with the provided GxDLMSDirector App and getting different results.. Android App is showing length one less in bytes and has a different output [in octetstring] and not decimal. Not sure what I am missing & what params need to be changed for identical information [Director app is getting it right]
The Android App has following Rx and Tx
Rx:7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
Tx: 7E A0 1E 41 03 74 31 0B E6 E7 00 C4 01 C1 00 09 0C 07 E6 0B 03 04 10 20 1B FF 01 4A 00 F8 70 7E
and the outcome PDU
<HDLC len="29" >
<TargetAddress Value="32" />
<SourceAddress Value="1" />
<!--I frame.-->
<FrameType Value="74" />
<PDU>
<GetResponse>
<GetResponseNormal>
<!--Priority: HIGH ServiceClass: CONFIRMED invokeID: 1-->
<InvokeIdAndPriority Value="193" />
<Result>
<Data>
<!--2022-11-03 16:32:27-->
<OctetString Value="07E60B030410201BFF014A00" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
</PDU>
</HDLC>
The Director app is getting the correct results
Rx:7E A0 19 03 41 FE 5A B1 E6 E6 00 C0 01 C1 00 01 00 00 60 01 00 FF 02 00 89 A0 7E
Tx: 7E A0 1F 41 03 1E D6 DB E6 E7 00 C4 01 C1 00 0A 0D 20 20 20 20 20 31 30 39 31 34 37 35 34 86 09 7E
PDU
<HDLC len="30" >
<!--I frame.-->
<FrameType Value="1E" />
<PDU>
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<String Value=" 10914754" />
</Data>
</Result>
</GetResponse>
</PDU>
</HDLC>
4 years ago
With android app you try to read clock object attribute index #2
http://gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
and with GXDLMSDirector you try to read data object attribute index #2.
http://gurux.fi/Gurux.DLMS.Objects.GXDLMSData
That is the reason why the result is different.
