  3. Execute Script From Script Table In Python
Execute script from script table in Python
By Vitaol , 14 June, 2022
I'm trying to execute a script from a script table using Python, the code I use is the following:
scriptTable = GXDLMSScriptTable("1.1.1.128.0.255")
script = GXDLMSScript()
script.id = 1
scriptTable.execute(client, script)
And I get the error:
AttributeError: 'GXDLMSScript' object has no attribute 'getId'
As far as I can see in the class definition it's true that there is no getId method:
https://github.com/Gurux/Gurux.DLMS.Python/blob/master/Gurux.DLMS.pytho…
Maybe I'm doing something else wrong?
4 years 1 month ago
You are right. I created an issue from this:
https://www.gurux.fi/node/19972
The new version is released today as this is tested.
4 years 1 month ago
Before the release you can use it like this:
script.id = 1
scriptTable.execute(client, script.id)
Vitaol
4 years 1 month ago
I tried and I can't get it to
I tried and I can't get it to work, I also tried the client.method() and didn't work either.
I'm thinking that maybe I have not configured the client correctly.
The DLMS command line is:
-h 192.168.1.54 -p 10004 -c 17 -a Low -P Password -w 1 -f 128 -t Verbose
In the code I configured as follow:
client = GXDLMSSecureClient(forAuthentication=Authentication.LOW)
client.useLogicalNameReferencing = True
client.clientAddress = 0x11
client.serverAddress =GXDLMSClient.getServerAddress(0,1)
client.password = 'Password '
client.interfaceType = InterfaceType.HDLC
client.ciphering.security = Security.NONE
It seems to be working because I can read and write data and read registers, but the script execution don't work and don't gives me any trace either so I'm a bit lost. Do you have any idea?
BR
Vitaol
4 years 1 month ago
Reading the dlms package after the execute seems to fix it.
I'll let the code here in case someone have the same doubt.
I use the reader class from the client example.
script.id = 1
data = scriptTable.execute(self.client, script.id)
reader.readDLMSPacket(data)
4 years 1 month ago
Yes, if you don't call readDLMSPacket the generated frame is not sent for the meter.
I'm glad that it's working now.
shgandhi
3 years 8 months ago
hi mikko ,
hi mikko ,
how this implemented in c code.
and i dont know the command line parameter for this script id.
My CLI parameters are:-
-h 2401:4900:4022:f9e4::2 -p 9083 -i HDLC -c 1 -a HighGmac -C AuthenticationEncryption -T 5753453030303031 -A AE90F90883AC70AF5BCE9D8060EE22F0 -B 22C8DA0AA7BBE7918F57296C4BE9FA23 -o Output.txt -v 0.0.43.1.0.255 -g 0.0.10.0.1.255:2
You can use those command line arguments with the ANSI C client example.
The client example only reads the data from the meter and you need to expand the client example to execute the script table as you wish.
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
