  3. Writing Into Physical Device
writing into physical device
By vicfretz , 22 May, 2022
i am trying to write into my meter. i want to be able to recharge my meter via obis code. how do i go about it
vicfretz
4 years 6 months ago
recharging meters via obis
recharging meters via obis /dlms protocol
You need to connect to the meter using a High authentication level. If the object's access rights is ReadWrite then you can write the value. Try to connect using GXDLMSDirector and try to write the value with that first. I believe it will help you to get an idea of how to write value for the DLMS meter.
vicfretz
yes i understand the writing
yes i understand the writing proces but i want to know if it is possible to write a token for a prepaid meter access via dlms. i mean is it possible to recharge my meter via that writing process
That depends on the meter. If the meter supports that and you have the access right for the meter it's possible.
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
  • Billiard Supplies | WA 083148835648
