hi Sir
If we use this
#ifdef DLMS_IGNORE_MALLOC
#define GX_OCTET_STRING(X, VALUE_, SIZE_) GX_UNION2(&X, pVal = VALUE_, (DLMS_DATA_TYPE) (DLMS_DATA_TYPE_BYREF | DLMS_DATA_TYPE_OCTET_STRING), SIZE_, sizeof(VALUE_))
, we have to comment #define DLMS_IGNORE_MALLOC , but you said it does not need to be used on the server؟
This server example doesn't use malloc. If you comment #define DLMS_IGNORE_MALLOC malloc is used and this server example doesn't work. I'll add Android server example that uses malloc for the worklist.
