  3. Error With Access Rights
Error with Access rights
By Jayaraj , 30 December, 2021
I am using GuruX director v8.2.2112.2101.
I added device as US association and I could read/write all US objects as expected. But when I read IC15 object for PC, being associated as US, objects are read successfully but post read, access right of all other objects are changed as per PC association. However if I again read IC15 object for US, all rights gets restored.
4 years 6 months ago
You need to refresh the access right if you change the authentication level. You can do that if you select "File" and "Refresh". After that, you can see the correct association rights. Access rights are read from the meter and GXDLMSDirector doesn't modify them.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
