  3. Reading The Data LNT DLMS METER
Reading the Data LNT DLMS METER
By Sudhakar , 17 September, 2021
Gurux DLMS for Android
After getting data from LNT DLMS METER, I am getting only 6 OBIS Data, to get full data of meter should i add OBIS and If i need add where to add
5 years 1 month ago
You need to change the client address and authentication level. Now you are using a public address and it shows only that data. When you are using Low or High, you can see more.
Sudhakar
5 years ago
Tq for the reply data is
Tq for the reply data is coming properly and Now I need to read 3 months of data from DLMS Meter is there any solution please help
5 years ago
You can use readRowsByRange method to read profile generic (historical value) with given range. Each meter is different and I believe that you should install GXDLMSDirector and read your meter with that. In that way, you get a better idea of your meter and what you can do with it.
Sudhakar
5 years ago
Tq for giving great advice to
Tq for giving great advice to read profile generic data and I got result like this..
Load profileIndex: 2 Value: [07 E3 01 01 FF 00 00 00 FF 01 4A 00 | 1000 | 65 | 0 |19 | 46 | 0 | 74 | 0 | 20 | 54 |
0 |
0 |
FF FF FF FF FF 00 00 00 FF 01 4A 00|
0 |
10
07 E4 0C 01 FF 00 00 00 FF 01 4A 00 | 1000 | 65 | 0 | 19 | 46 | 0 | 74 | 0 | 20 | 54 | 0 | 0 | FF FF FF FF FF 00 00 00 FF 01 4A 00 | 0 | FF FF FF FF FF 00 00 00 FF 01 4A 00 | 4
Index: 3 Value: [Register 0.0.0.1.2.255,
Register 1.0.13.0.0.255,
Register 1.0.1.8.0.255,
Register 1.0.1.8.1.255,
Register 1.0.1.8.2.255,
Register 1.0.1.8.3.255,
Register 1.0.1.8.4.255,
Register 1.0.9.8.0.255,
Register 1.0.9.8.1.255,
Register 1.0.9.8.2.255,
Register 1.0.9.8.3.255,
Register 1.0.9.8.4.255,
ExtendedRegister 1.0.1.6.0.255,
ExtendedRegister 1.0.9.6.0.255,
Register 0.0.94.91.13.255]
Index: 4 Value: 0
Index: 5 Value: 0
Index: 6 Value:
Index: 7 Value: 0
Index: 8 Value: 0
And now I need to parse this hex value 07 E3 01 01 FF 00 00 00 FF 01 4A 00 which is OBIS is 0.0.0.1.2.255(Billing Time)
5 years ago
If you read capture object (attribute #2), values are converted automatically.
You can convert byte array to date time using GXDLMSClient's changeType method. Like this:
GXDLMSClient.changeType(bytearraty, DataType.DATE_TIME, false);
  • APFC TEAM1
