  3. Arduino Server Mobile APP
By JorgeM , 13 September, 2021
Gurux DLMS for Android
Hi!, I'am trying to communicate an Gurux arduino server with the Gurux Android mobile application, I have verified the OTG port connecting it with a terminal application with the debug port and the communication works. But when trying to communicate with the arduino server don't get any response. Is such communication possible between the arduino server and the mobile application?
On the other hand, the arduino server works well with Gurux python and c clients running on linux.
(in refernce abut the last comments, the IEC protocol doesn works and Landys meter doesn't exist in the list )
Thanks a lot
Greetings
George
5 years 1 month ago
Are you getting any reply from the meter? You need to select Gurux as the manufacturer if you want to connect to the Arduino example meter.
IEC protocol is used if you are communicating with the optical probe.
JorgeM
5 years 1 month ago
Thank you a lot Mikko!
Thank you a lot Mikko! I send a screenshots atached for more info!
JorgeM
5 years 1 month ago
Manofacturers
Manofacturers
JorgeM
5 years 1 month ago
Manofacturers 2, I don't find
Manofacturers 2, I don't find an Arduino item in the list! I configure Value and I try with this option!
JorgeM
5 years 1 month ago
Trace!
Trace!
JorgeM
5 years 1 month ago
Configuration
Configuration
JorgeM
5 years 1 month ago
Serial Port CH340
Serial Port CH340
JorgeM
5 years ago
Hi Mikko
Hi Mikko
the Arduino and App is working!!!!!, I had to change the serial to USB converter! from a ch340 to a cp2102 and it worked fine!
It's very strange because the ch340 works with a common terminal! (and it works like a debug port)
Thanks a lot!
Jorge
5 years ago
Hi Jorge,
Hi Jorge,
Thank you for this information. In my mind, there is one HL-340 converter in the office, so this can be tested. If not, HL-340 is ordered, but it will take some time. :-(
I hope that this can be repeated, so we'll know the reason for this.
  • APFC TEAM1
