  3. Read Load Profile With Filters
Read Load Profile with filters
By taher_alfalah , 12 August, 2021
Gurux DLMS for Android
We are trying to read the load profile using Gurux android, it is read successfully, but it returns a huge amount of data, we tried to add filter range without success, appreciate your help in how to read specific period using the android version.
here is below the code we are using.
GXDLMSProfileGeneric obj = new GXDLMSProfileGeneric("1.0.99.1.0.255");
Calendar start= Calendar.getInstance();
start.set(2021,7,20);
Calendar end= Calendar.getInstance();
end.set(2021,8,11);
readObject(_mDevice,_mClient,obj ,2);
_mClient.readRowsByRange(obj ,start.getTime(),end.getTime());
obj .getBuffer();
Best Regards
5 years 2 months ago
It looks correct. It might be that meter can't handle the time zone. If you can read the meter with GXDLMSDirector and add Read by range trace here I can check clock settings.
taher_alfalah
our optical prop doesn't support connecting on a desktop so I cannot read it.
if there is another option to get this info by android or to enable reading periods
best regards
sachinar007
3 years 9 months ago
Hi, We are trying the same…
We are trying the same thing as reading works if we use "readObject(profileGeneric, 3);(Capturing Objects)" and "readObject(profileGeneric, 2);(The Buffer Data)".
But it returns Exception like "Failed to get the certificate." from GXDLMSSettings.java class when we try to call "byte[][] data = mClient.readRowsByRange(pg, start, end);" OR "byte[][] data = mClient.readRowsByEntry(pg, 10, 10);"
Here is the Calendar date config...
readObject(profileGeneric, 3);//Capturing Objects first as expected
Calendar start = Calendar.getInstance();
start.set(Calendar.HOUR_OF_DAY, 0);
start.set(Calendar.MINUTE, 0);
start.set(Calendar.SECOND, 0);
start.set(Calendar.MILLISECOND, 0);
Calendar end = Calendar.getInstance();
end.set(Calendar.SECOND, 0);
end.set(Calendar.MILLISECOND, 0);
byte[][] data = mClient.readRowsByRange(pg, start.getTime(), getTime());
//////////////////////////Please find the Trace from GXDLMSDirector below////////////////////////////
16:26:52 Read object type ProfileGeneric index: 4
TX: 7E A0 2C 03 61 54 9C BA E6 E6 00 C8 1E 30 00 00 00 76 65 46 E1 D0 7E 96 75 E5 D8 02 FB FC 20 59 6C A3 B0 A1 25 1C FF 4C F6 8C 0B 6E F1 7E
16:26:52
RX: 7E A0 28 61 03 74 62 0F E6 E7 00 CC 1A 30 00 04 0A F0 46 D4 BD B9 AA AB 42 63 7A 81 36 C4 C2 FE 05 8A BA 78 60 9F 90 F1 62 7E
16:26:52 Read object type ProfileGeneric index: 5
TX: 7E A0 2C 03 61 76 8C B8 E6 E6 00 C8 1E 30 00 00 00 77 04 DE 07 98 73 17 B2 85 B9 ED 02 20 4C 4B ED 23 DC 26 47 86 95 D2 A3 FE BA 1C 80 7E
16:26:52
RX: 7E A0 25 61 03 96 F1 40 E6 E7 00 CC 17 30 00 04 0A F1 E8 7D 08 13 CF 49 24 55 13 01 2B 65 EB 87 B8 A8 81 27 A6 C8 7E
16:26:52 Read object type ProfileGeneric index: 6
TX: 7E A0 2C 03 61 98 FC B6 E6 E6 00 C8 1E 30 00 00 00 78 01 9C 4F B6 83 C6 BF 9E 99 73 CB CE 0E 3A 09 AD A8 EB 5C 0C F3 8B 22 E8 6B 56 D4 7E
16:26:52
RX: 7E A0 35 61 03 B8 2C 4B E6 E7 00 CC 27 30 00 04 0A F2 39 8D 0F 90 79 9F EE A0 FE 8F BE 6A 6C 13 17 30 B2 74 CD 0C 97 F9 49 E1 52 36 66 B1 C9 68 6C 1C 88 73 2C 8A 7E
16:26:53 Reading profile generic data
TX: 7E A0 5F 03 61 BA 64 CB E6 E6 00 C8 51 30 00 00 00 79 49 75 1E 7B C8 AD DE 46 70 B9 EE 55 54 FB CE 11 00 B8 FF 1E EB D4 47 2D FF A4 B7 96 40 86 B8 49 32 B3 6C 4E 9F A6 58 3E BB C0 51 4D EB CE 1F 80 41 93 1C 86 B8 01 82 15 BB 75 FC 67 27 67 C1 00 78 13 09 31 A8 A7 42 D8 D4 68 B4 AE 6E 0F 7E
16:26:54
RX: 7E AA 4C 61 03 DA B6 E4 E6 E7 00 CC 82 04 30 30 00 04 0A F3 AB A4 29 E2 6C 57 52 60 DA 71 EA A3 FF F4 42 A8 DD 02 B9 03 C3 8D EF F0 2D 44 E9 A4 BA 6C F1 2E A5 ED 71 7E C7 63 0A 24 0B 8D 3C AC 0F 3E 76 49 80 0F 38 0F 02 D4 B5 BB 73 60 E0 F1 90 7D 42 E2 91 D7 99 6B F1 91 DE E4 C2 44 FF 07 F2 BC 25 85 00 7A 16 12 5D 97 FA FC 07 62 93 7A 87 81 87 B1 77 74 55 0C 10 54 8E 47 AF 5C 6F 8A 7A 86 20 90 9C 2A 2B 85 01 89 E1 50 B3 95 8A BF 09 89 03 8D 76 A4 34 9A B3 B5 39 55 34 41 66 1F 25 F5 7D 10 34 E6 36 48 20 69 88 E5 72 DD B1 72 2C 50 77 6E FC 6E 42 B1 E0 51 C0 5D 54 43 66 83 3F 29 D4 ED 7D 89 77 84 29 01 0E 03 08 15 72 FC 35 5D 91 51 9F DA E7 42 74 CA C4 3A F1 1C 22 11 39 4A 5C AE D2 B4 EB D3 8D 69 09 E9 2D 17 F2 5B 54 9C C7 3A ED 5E E7 BA 43 E7 6D E7 CA 09 27 BA 56 48 07 09 F6 15 BC 38 02 D7 85 39 8C D8 BF 10 EA B6 92 4F C5 55 D9 5C 37 7F 5E C2 76 56 60 61 13 D0 E8 22 C6 BF 15 A6 38 A8 F0 53 49 AB EE 66 26 E8 5A 6F 36 1C DA 6E 39 C9 44 BA 47 75 17 10 42 D3 77 A4 F8 63 1B 49 D6 32 7D 55 61 A0 42 27 24 DF 9A A0 9E 62 20 4B A3 8A D3 56 46 73 63 A8 86 37 B9 DA 2D 42 CF 89 AA 63 EA FA 9F C1 75 AE 7A 8B F3 7D B2 24 74 B8 81 8B 78 8E BE 0C 11 48 13 96 DE F1 32 18 61 14 4D B9 4D 76 1C 44 23 F6 CA 81 99 61 C2 B0 FA 56 75 32 30 81 AD 5A E1 4C 54 0F C4 90 E5 53 C7 7E 72 75 8B 3A 72 A0 A0 DA 4F 5E 07 FA 16 E9 7E 9E D8 85 A8 CA B9 92 E4 4B 6C 4B 45 C8 4B 66 80 AF 53 71 2E E7 62 98 E4 08 A0 34 46 74 92 BB 80 94 A2 51 82 BC 0C 5B AB 66 EC 9E CA D9 84 37 8C 89 3F 9D 0A DD 39 53 94 44 B5 67 BD 57 0C AD 26 B9 FC E5 5F FA A2 C3 AA F9 04 66 F7 97 E8 61 F0 5C 2E F8 92 AA 3D 59 19 00 98 20 D2 79 A1 70 57 1D D3 1D 85 DF BD ED 02 47 E7 95 34 11 D8 0C 3D 2D 26 0A A1 38 91 52 C4 62 E8 38 DC 05 73 1D 8D C0 BB 36 51 63 F9 6C 76 28 F9 4F 2A 68 8A C5 4C 3C EE 95 B0 34 E7 7E
16:26:54
TX: 7E A0 07 03 61 D1 7F 26 7E
16:26:54
RX: 7E A1 FD 61 03 DC 4B BB 9C 7E 09 0C F2 D2 D8 47 18 5E 5D DD 62 33 8B 91 C9 DE A1 8C 52 28 DF EC A7 9F 90 B7 F6 6B A8 BC D0 A8 25 22 80 42 6E 78 BC B6 9E DF 04 9F 51 2D 71 5D 00 AA 3F BC 34 74 0D 83 F6 0B F7 32 69 25 77 82 69 D0 2E 30 A5 C4 DB D4 CF 91 DB 52 1D BB EF EF F1 DA D9 7A 93 8A C2 27 2F 39 0E BE 2B 74 55 D1 17 80 63 E7 2D 4C 67 28 58 2E 99 7C E0 59 A0 69 CC 0D 0A BD FD 9A E8 59 B1 2E 63 8A 7E 6A 26 12 19 F4 9D BE 63 C1 09 B8 F8 7B D7 BD C0 9E 8D 5E 56 EF E4 40 81 A3 C9 37 72 DE 6F 72 22 60 1F E3 BC D8 5B D7 A2 0C 41 BB 2D 86 64 2F 33 54 76 00 01 C3 C2 0C A0 F5 E4 92 AC 1D 17 71 EB B1 84 27 A3 00 76 9E 6A 23 5D 68 78 40 26 4E BE FA DF 2F 60 CF C2 85 E5 9D 2A 5A 11 0C 89 08 07 A9 04 42 D4 A7 C1 84 54 A5 FF DE 14 3E 07 34 4B 89 70 F8 00 06 10 88 A0 06 5F 3B 40 B0 25 41 42 7F F4 2B 8D DE 67 F9 2E 5B 2D 73 EA BE CE 6E 5B 3D 4F 9C 29 85 58 E3 0E 1D 2C B4 CD F8 B6 2B 09 38 4F 97 12 05 98 AB 78 29 E6 F5 D6 81 83 82 B7 0E E9 1C DB 50 97 71 31 0E 67 F6 0A 60 E5 70 DD BF 92 AA F7 11 1D 53 D2 0D DF F3 FA 47 66 16 9B 74 C5 99 F3 4D C3 1D 95 62 33 89 9C EB 1E 2D 47 35 9A 41 34 31 76 C2 FB 22 2F CD DD 98 68 09 FF C1 E6 1F 93 3B F8 E5 17 45 E9 B5 E8 8E 01 0C D9 CE 2E 89 93 B9 03 B3 7F 6A DA EB F5 B6 4D 36 A1 E6 BD F3 4A 14 EF 1C FF A5 82 10 2C 4F 7E 61 25 2F 52 4F FB C1 FA 68 1D EB 33 03 7E AE CF AE 29 DA 6D 4C 84 6E EB 10 E9 1E 58 B0 8B 49 A2 B1 B3 6A B9 E2 CE B0 31 9A BD 8E 64 CE 72 E3 7C E3 B3 18 28 B1 25 3C 23 F8 3A 17 6F 02 F2 E7 FF DB 87 53 A3 BB 7C 65 EF 95 A1 A9 58 33 EB 9B 3B 4B B2 A8 70 C9 D8 E1 A4 0D 7E
16:26:54
TX: 7E A0 26 03 61 FC 70 4F E6 E6 00 C8 18 30 00 00 00 7A 93 50 A4 CB CD 94 07 0B 21 0B 88 94 7C 59 0E 67 A5 6E 24 1B 95 7E
16:26:55
RX: 7E AA 4C 61 03 FE 90 83 E6 E7 00 CC 82 04 30 30 00 04 0A F4 97 EA 70 F8 FD 4C 96 69 85 65 7B 1C 18 A2 93 B9 40 68 0C A4 B8 60 95 9D 6A 3D 11 FE 3E 08 FB D9 78 FF 8A 1D F8 C7 4C 12 C3 E2 C8 6D EE 3F EE 99 91 BC 5E 54 04 09 34 79 AF 4B 37 0B 18 85 5C 2F B3 36 1D 25 EA E8 61 F0 78 0B CB FB AA 4E 29 82 E8 AA 69 9E EE 43 6C F2 40 75 6F 8F CA D6 FA CE D9 89 92 BC 30 89 94 E1 C7 8B 03 49 7F 3B 44 A8 C3 58 71 98 53 A9 23 BE DA 89 B8 3A BE 0A D0 B8 27 D0 4F 06 14 E0 28 84 D4 36 64 A0 3A 00 A3 E4 D4 23 A2 45 DC DC CE E3 A6 35 30 A1 AE DF 75 FF 03 F3 17 00 83 E4 18 45 F6 6F EF 19 B6 F0 94 02 AD 4F 7F 9D 79 E4 C8 F5 56 54 45 61 8A A7 6F 08 CE A6 5E DB BD E9 3A 5E 07 BC 7E 3B 25 21 11 74 A8 D1 02 BB 4E 8A F4 D9 A3 56 AF 59 62 21 8A 96 9C D4 4E 47 7B 28 D6 2C 16 1F 39 29 97 1A 57 67 93 53 9C F4 0C B7 D0 34 24 5E 49 EC 4D DC 6F DD 2B 20 58 D2 21 01 DE 36 6C B9 E5 41 A9 DE E8 6E 7B 25 80 10 2B 7C 4D C9 E9 07 F6 D1 3C F8 D3 71 83 AA A0 8A CB 63 B1 CB D9 77 CF 42 E1 00 07 7E 12 15 0E E3 C7 34 83 E2 1C 3D DA 48 B5 0E EF 16 67 E3 D6 C9 E1 EB C8 38 05 22 A3 EE EE 33 24 7D 4C F2 7B 4E 2F 73 20 B1 61 49 25 BD 74 35 F8 FE 59 57 58 C2 22 D1 CA 68 E8 C6 99 C7 DC 09 0E 6F 8D 01 76 19 FD 16 DC 1B 42 60 27 8E B4 04 1E 66 11 D4 08 EB 66 BB 2B 09 14 A3 A1 C2 B8 74 7C FE 21 BB 15 48 94 44 19 A9 43 41 4D C8 37 70 99 23 6B 2C AB 84 F4 4C C9 44 AC 76 44 86 E7 28 64 52 D3 5E ED 0F 27 89 78 0C 51 AC DA F8 55 29 C9 E0 D6 10 5A 05 13 06 E4 E5 FD 02 B4 5A 81 F5 0E E0 89 AF F9 E0 30 57 6E 18 69 D5 43 5B 8D 20 52 9C 87 2B 52 7D 89 3E 60 33 32 9E 08 5F 45 FC BE 8F 82 26 51 AE 2C 75 EA E5 3E 9B 33 A2 F8 AA 3F 58 77 46 8F 96 77 E2 36 56 5F F5 38 5C 9D 03 DB 95 4E FA 57 90 66 B7 D7 ED 4E 92 2C 21 6D AF 4F 38 63 5D 79 9B C5 94 91 DE EB 83 3B D4 BD 83 09 BE AC 16 09 39 7A DD 80 FB 47 7E
16:26:55
TX: 7E A0 07 03 61 11 73 E0 7E
16:26:56
RX: 7E A1 FD 61 03 F0 25 50 0F AA 05 DD 5F 38 5D F2 BA 9A 0E 38 68 41 2C 4A 10 4F E5 A1 8A A0 51 5A FD 09 3F A5 5D D1 3A D7 84 7F 8B 08 8E 1F BF 4B C8 25 B5 2F 69 94 E8 80 37 7E C0 AF C2 4E 88 CA 49 BB 13 C8 3D 30 C8 24 7A C8 31 6B 89 F6 D8 1E FD 55 F9 F3 24 9F 4C 02 27 20 BB C4 B8 10 23 24 B1 59 F9 1A 15 A1 98 33 49 FE 52 48 16 66 25 C1 3E CE AF C5 88 68 A1 94 E0 75 7A 83 8F F8 84 1A 16 0E C8 C4 9D A7 31 53 DC FC 62 B5 94 D1 DE D1 D5 6D 85 91 1D 63 21 AF BB F2 CB 37 7D 2F E9 0B 8E 7C A2 B7 68 85 BC 8E 37 4D CE 90 62 11 A8 AD E7 3F EF 3C 01 4C E8 11 67 7B B1 45 F1 66 4B 04 7A 1C B4 08 BB 1D C6 BF 81 02 F7 6E 38 9C 0A 9C 62 20 0C 02 F4 50 F2 83 C6 1D 97 33 ED 5E B8 64 D4 80 55 23 68 1F D2 0A 81 E3 F9 14 33 20 94 25 4C F8 3C 19 44 17 9A BF 8A 07 BB 19 E2 85 94 93 17 98 89 1E CC FD BD 17 42 86 F0 B8 3D 62 4C 5C 28 F6 42 83 55 C8 C9 31 B1 2D 03 CC FF AF 17 46 22 CD C2 C4 ED 18 98 ED AE B1 8E C4 04 4C 66 C6 6B 22 27 9B B7 74 EA A3 BC CB 5D E5 2B CD 25 5D 4C 06 94 D7 4F 8C 91 D1 3D 12 65 91 62 D8 AF D7 84 3A 76 77 12 83 F4 1A C1 4F 4C D3 FD 59 E4 62 58 8A 8F DB 3D 64 3E 1D E6 B5 83 19 DE BE E8 0A 72 C7 6B BC 1B E2 05 08 80 8E C8 00 E7 15 CF 8E 16 32 77 14 3A 82 97 DA B1 1F 74 BC 4E 02 B9 8A BD 9A 91 E9 92 58 AB 1B 36 65 60 04 E7 AC 10 E6 2B 96 6A 08 CA 48 5B 47 9C 7E CC 12 48 E8 5A 4A FB F9 E3 65 71 C7 CA 5E 48 C1 E5 C7 9E 3F B3 DF C0 18 16 F9 6A 38 F6 07 28 DE 82 D9 CB 20 B2 39 50 FF 37 70 06 2E 5A 29 AA 65 E8 54 C0 7D AF B1 6D 2F 36 F7 E9 8B CD 6F E0 E6 F4 BE D0 A9 4E 35 6F E0 1F A7 31 39 EE 03 F2 07 72 FF F2 FF 7E
16:26:56
TX: 7E A0 26 03 61 3E 6E AA E6 E6 00 C8 18 30 00 00 00 7B A9 11 96 AA B5 06 13 68 8F 5C EF 90 20 64 E9 36 E3 F2 17 14 25 7E
16:26:56
RX: 7E A0 63 61 03 12 F0 DF E6 E7 00 CC 55 30 00 04 0A F5 5F 03 85 FB FC 1C 08 D0 5A F8 21 56 B3 FC 5F 59 EF 2E 4E F4 24 3D EE 61 80 40 EB BC 55 C2 30 B2 4B 2F 05 76 A5 6F CA F8 06 09 70 D4 5F E6 6A E8 F5 A1 28 97 B4 FB A8 8B B7 73 6A 5C 3C DF B8 4B 08 3B 26 20 33 8F C7 C5 7C DB 90 0D 0C 5C F4 7F 3E F2 7E
16:26:56 Read object type ProfileGeneric index: 7
TX: 7E A0 2C 03 61 50 B8 FC E6 E6 00 C8 1E 30 00 00 00 7C F4 96 18 FD 5E 30 2E F5 57 81 0F 57 63 0E 98 94 13 FB AD E7 1E 7A 1E 4C 86 2B B4 7E
16:26:57
RX: 7E A0 28 61 03 34 66 4D E6 E7 00 CC 1A 30 00 04 0A F6 AD 10 B6 BA CD 4D F7 5E 98 77 09 91 00 68 02 D1 13 A1 8F 00 94 53 78 7E
16:26:57 Read object type ProfileGeneric index: 8
TX: 7E A0 2C 03 61 72 A8 FE E6 E6 00 C8 1E 30 00 00 00 7D 8E 65 F9 BF 49 28 74 46 4B 34 2C 8F C5 A7 CC DE 45 57 40 9C 28 8B 8D 01 B4 3C BE 7E
16:26:57
RX: 7E A0 28 61 03 56 72 0D E6 E7 00 CC 1A 30 00 04 0A F7 D8 BC 08 66 54 A7 62 57 46 03 BF A0 69 2A 1B 36 B0 CE D5 93 F0 F2 75 7E
sachinar007
3 years 8 months ago
Hi sir, we are waiting for…
Hi sir,
we are waiting for your response, we had given the GXDLMS Director response (Trace) in the previous comment already.
we are getting CaptureObjects successfully and also Buffer(Entire) but the problem is we want to read only between the specified range.
mClient.readRowsByRange(profileGeneric,start.getTime(),end.getTime());
is not giving the response it throws the exception "Failed to get the certificate". I have already mentioned these in the previous comment please respond sir.
https://www.gurux.fi/index.php/comment/25702#comment-25702
3 years 7 months ago
In reply to Hi, We are trying the same… by sachinar007
Hi, Please, if you have a…
Please, if you have a new question create a new topic.
The original question is so old that I don't get the notifications because it's closed.
Your data is encrypted. I need the block cipher and authentication keys to solve this. Can you create a new topic where we can continue this.
