  3. Can't Read Profile Generic Billing Profile(IOBIS:1.0.98.1.0.255) By Com_readRowsByRange()
Can't read Profile Generic Billing profile(IOBIS:1.0.98.1.0.255) by com_readRowsByRange()
By mightyChamp , 13 May, 2021
I am trying to get Billing Profile. It can be accessed by com_readRowsByEntry(), but no data in index 2 when read by com_readRowsByRange(), with start and end time.
com_readRowsByEntry
Other OBIS like "1.0.99.2.0.255" Daily Load profile. works on both functions com_readRowsByEntry() and com_readRowsByRange(). I used similar way as of "1.0.99.2.0.255" for Billing, but it is not working.
For start time and end time , I first read clock, and give its value to end time and start time, and by function time_addDays(), I substract 90 days from start time. then use start and end time in com_readRowsByRange(), as described below:
startTime=endTime=clock1.time;
hrs=0-hrs;
time_addDays(&startTime,90);
com_readRowsByRange(&pg,&startTime,&endTime);
Please help me to solve this issue, I want to read data between time period.
Thank You
mightyChamp
5 years 2 months ago
Hello, please help me as soon
Hello, please help me as soon as possible.
Thank You
Can you read this with GXDLMSDirector? Some meters expect that the minutes and seconds are set to zero. Check first that.
mightyChamp
I also tried by clearing
I also tried by clearing minute and hour value but still facing issue. and I can read data by GXDLMSDirector.
Can you add the GXDLMSDirector log? Only the read command is enough so I can check the bytes.
  • agize
  • BioTips
  • Vital479
  • HealthPro16
  • Brandondiz
