  3. Service Unsupported Error When Using Version 8.2.2103.1001. Older Version Works Fine.
Service Unsupported Error when using version 8.2.2103.1001. Older version works fine.
By aashishkul , 16 March, 2021
I am trying to read Secure Meter Indian Standard meter using Gurux GXDlmsDirector.
When I try to read the meter data, GX Dlms Director shows error "Service Error Read exception. Service Unsupported".
Older version of Gurux GX Dlms Director is working fine (which is installed on another PC.)
Here is the log file-
GXDLMSDirector 8.2.2103.1001
Log created 15:34:15
15:34:25 Initializing Network connection.
15:34:26 Send AARQ request.
00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF
15:34:26
00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 01 00 00 07
15:34:26 Parsing AARE reply succeeded.
15:34:30 Access Request
00 01 00 10 00 01 00 13 D9 C0 00 00 01 00 01 01 00 01 01 00 00 00 06 FF 02 01 00
15:34:30
00 01 00 01 00 10 00 04 0E 05 03 02
Gurux.DLMS.GXDLMSConfirmedServiceError: ServiceError Read exception. Service Unsupported
at Gurux.DLMS.GXDLMS.HandleConfirmedServiceError(GXReplyData data)
at Gurux.DLMS.GXDLMS.GetPdu(GXDLMSSettings settings, GXReplyData data, GXDLMSClient client)
at Gurux.DLMS.GXDLMS.GetData(GXDLMSSettings settings, GXByteBuffer reply, GXReplyData data, GXReplyData notify, GXDLMSClient client)
at Gurux.DLMS.GXDLMSClient.GetData(GXByteBuffer reply, GXReplyData data, GXReplyData notify)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[][] data, String text, GXReplyData reply)
at GXDLMSDirector.GXDLMSCommunicator.AccessRequest(DateTime time, List`1 list)
at GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
15:34:33 Release request
00 01 00 10 00 01 00 05 62 03 80 01 00
15:34:33
00 01 00 01 00 10 00 05 63 03 80 01 00
aashishkul
5 years 4 months ago
Removing "Access" from
Removing "Access" from "Supported Service" tab makes it work fine.
Thank you for this info. I created an issue from this.
https://www.gurux.fi/node/18121
This is fixed and the new version is released today.
aashishkul
Thank you. I got the update
Thank you. I got the update when I started the application again and this time everything worked like charm.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
