  3. Issue Regarding G3-PLC Interface Classes - 91 and 92
Issue regarding G3-PLC Interface Classes - 91 and 92
By anudeep02 , 2 February, 2021
Hello Mikko,
I'm facing an issue with G3-PLC interface classes - 91 and 92.
For IC91 (G3PlcMacSetup)
- Write request is not sent from GuruX software for Key Table and Neighbor table attributes. Also Method is not visible.
For IC92 (G3Plc6LoWPan)
- Write request is not sent from GuruX software for Routing Table attribute.
I'm adding/Editing the data, but data is not written in meter. I verified the access rights for the attributes, and it is correct.
Can you guide me if I'm correctly following the procedure? Please let me know if you need more information on this.
Thanks and Regards,
Anudeep Bhagwat
5 years 9 months ago
You are right. I made issues from those.
Key Table and Neighbor table write is not possible in G3-PLC MAC Setup.
https://www.gurux.fi/node/17791
Routing Table write is not possible in G3-PLC 6LoWPAN adaptation layer setup.
https://www.gurux.fi/node/17792
They are fixed for the next release. We try to release it during this week.
anudeep02
Hello Mikko,
Hello Mikko,
Thank you for your quick response. Hope to receive new release soon, so I can proceed further.
Have a Great Day Ahead...!!!
Thanks and Regards,
