  3. Problem With SL7000 Billing Profile
Problem with SL7000 Billing Profile
By juma , 13 July, 2020
I am new to using Gurux and I am trying to read the Billing Profile of an SL7000 meter and I encounter the following problem:
I have only been able to read the last set, I have tried 2 different meters that have different firmware and I always get the last set.
On the other hand, I downloaded the historical data from both meters with ACE PILOT and I get all the SETs stored, but with Director or with the Python client example only the last one.
I would like to know what I am doing wrong or what is the limitation and would appreciate the help.
Attached screenshots.
Best regards,
Juan
6 years 2 months ago
SL7000 is older meter and it's support for DLMS is not very good. Can you get the trace from ACE PILOT and I can check that it's using DLMS to read the meter. There are different versions from the meter and all are not using DLMS. I need to see only what app sends for the meter, not all the replies.
juma
Thanks for your answer.
The meter is an SL7000 761 with firmware version 7.24.
I could send you by private mail IP and connection port for you to verify it, is it possible?
The trace of the GXDLMSDirector is as follows:
GXDLMSDirector 8.2.2007.0602
Log created 7:55:39 PM
19:55:50 Initializing Network connection.
19:55:50 07:55:50.598 Info Opening
19:55:50 07:55:50.645 Info Open
7:55:51 PM Send SNRM request.
7E A0 08 02 23 03 93 3E 74 7E
19:55:51 07:55:51.161 Sent 7E A0 08 02 23 03 93 3E 74 7E
19:55:52 07:55:52.645 Received 7E A0 23 03 00 02 00 23 73 C0 48 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
7:55:52 PM
19:55:52 Parsing UA reply succeeded.
7:55:52 PM Send AARQ request.
7E A0 45 02 23 03 10 FB 7F E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7E
19:55:52 07:55:52.645 Sent 7E A0 45 02 23 03 10 FB 7F E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7E
19:55:53 07:55:53.456 Received 7E A0 53 03 00 02 00 23 30 13 29 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 01 AA 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 21 34 00 07 9A C7 7E
7:55:53 PM
19:55:53 Parsing AARE reply succeeded.
7:56:38 PM Reading profile generic data 0.1.98.1.0.255
7E A0 2D 02 23 03 32 78 86 E6 E6 00 C0 01 C1 00 07 00 01 62 01 00 FF 02 01 02 02 04 06 00 00 00 01 06 00 00 00 03 12 00 01 12 00 00 95 7A 7E
19:56:38 07:56:38.029 Sent 7E A0 2D 02 23 03 32 78 86 E6 E6 00 C0 01 C1 00 07 00 01 62 01 00 FF 02 01 02 02 04 06 00 00 00 01 06 00 00 00 03 12 00 01 12 00 00 95 7A 7E
19:56:41 07:56:41.746 Received 7E A8 8C 03 00 02 00 23 52 9D A9 E6 E7 00 C4 01 C1 00 01 01 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1E 02 02 0F 00 16 04 02 02 11 15 11 14 09 0C 07 E4 07 01 03 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 05 2D 89 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 05 08 5A 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 05 95 0B 02 02 0F 03 16 1E 02 03 09 06 01 01 01 08 00 FF 06 49 94 7E
7:56:41 PM
19:56:41 Get next frame.
7:56:41 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 51 20 91 7E
19:56:41 07:56:41.746 Sent 7E A0 08 02 23 03 51 20 91 7E
19:56:42 07:56:42.590 Received 7E A8 8C 03 00 02 00 23 54 AB CC 00 0F EA 52 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 02 1A 4D 02 02 0F 03 16 20 02 03 09 06 01 01 2B 08 00 FF 06 00 02 98 9B 7E
7:56:42 PM
19:56:42 Get next frame.
7:56:42 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 71 22 B0 7E
19:56:42 07:56:42.590 Sent 7E A0 08 02 23 03 71 22 B0 7E
19:56:43 07:56:43.495 Received 7E A8 8C 03 00 02 00 23 56 B9 EF 52 0C 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 02 D0 45 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 07 4B 1A 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 08 00 FF 06 00 00 0E 7A F5 EA 7E
7:56:43 PM
19:56:43 Get next frame.
7:56:43 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 91 2C 57 7E
19:56:43 07:56:43.495 Sent 7E A0 08 02 23 03 91 2C 57 7E
19:56:44 07:56:44.371 Received 7E A8 8C 03 00 02 00 23 58 C7 06 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 02 1A 4D 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 02 52 0C 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 02 D0 45 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 07 3C A0 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 FF 06 00 00 00 00 02 02 1C EC 7E
7:56:44 PM
19:56:44 Get next frame.
7:56:44 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 B1 2E 76 7E
19:56:44 07:56:44.371 Sent 7E A0 08 02 23 03 B1 2E 76 7E
19:56:45 07:56:45.369 Received 7E A8 8C 03 00 02 00 23 5A D5 25 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 00 00 0E 7A 02 02 0F 03 97 47 7E
7:56:45 PM
19:56:45 Get next frame.
7:56:45 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 D1 28 15 7E
19:56:45 07:56:45.369 Sent 7E A0 08 02 23 03 D1 28 15 7E
19:56:46 07:56:46.323 Received 7E A8 8C 03 00 02 00 23 5C E3 40 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 05 9B CA 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 05 8C F0 02 02 0F 03 16 1F 67 03 7E
7:56:46 PM
19:56:46 Get next frame.
7:56:46 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 F1 2A 34 7E
19:56:46 07:56:46.323 Sent 7E A0 08 02 23 03 F1 2A 34 7E
19:56:47 07:56:47.307 Received 7E A8 8C 03 00 02 00 23 5E F1 63 02 03 09 06 01 01 45 08 00 FF 06 00 06 43 9A 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 11 8E E9 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 02 02 0F 03 16 1F 02 03 3C 77 7E
7:56:47 PM
19:56:47 Get next frame.
7:56:47 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 11 24 D3 7E
19:56:47 07:56:47.307 Sent 7E A0 08 02 23 03 11 24 D3 7E
19:56:48 07:56:48.274 Received 7E A8 8C 03 00 02 00 23 50 8F 8A 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 27 EA 7E
7:56:48 PM
19:56:48 Get next frame.
7:56:48 PM Reading profile generic data 0.1.98.1.0.255
7E A0 08 02 23 03 31 26 F2 7E
19:56:48 07:56:48.274 Sent 7E A0 08 02 23 03 31 26 F2 7E
19:56:49 07:56:49.151 Received 7E A8 8C 03 00 02 00 23 52 9D A9 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 01 01 02 04 02 05 5A 64 7E
7:56:49 PM
19:56:49 Get next frame.
7:56:49 PM Reading profile generic data 0.1.98.1.0.255
19:56:49 07:56:49.151 Sent 7E A0 08 02 23 03 51 20 91 7E
19:56:50 07:56:50.085 Received 7E A8 8C 03 00 02 00 23 54 AB CC 09 06 01 01 01 08 01 FF 06 00 03 A5 BE 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 03 32 EB 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 09 11 A9 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 07 4B 1A 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 07 BD 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 33 00 FF 80 00 FF 02 03 12 B3 B2 7E
7:56:50 PM
19:56:50 Get next frame.
7:56:50 PM Reading profile generic data 0.1.98.1.0.255
19:56:50 07:56:50.101 Sent 7E A0 08 02 23 03 71 22 B0 7E
19:56:50 07:56:50.977 Received 7E A8 8C 03 00 02 00 23 56 B9 EF 07 BC 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 32 00 FF 80 00 FF 02 03 12 07 BC 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 31 00 FF 80 00 FF 02 03 12 07 BB 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 34 00 FF 80 00 FF 02 03 12 07 B8 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 30 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 06 33 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 04 00 08 5B 7E
7:56:50 PM
19:56:50 07:56:50.977 Sent 7E A0 08 02 23 03 91 2C 57 7E
19:56:51 07:56:51.853 Received 7E A8 8C 03 00 02 00 23 58 C7 06 FF 80 00 FF 02 03 12 06 31 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 03 00 FF 80 00 FF 02 03 12 06 30 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 05 00 FF 80 00 FF 02 03 12 06 2C 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 06 00 FF 80 00 FF 02 03 12 06 2B 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 0D 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 0A CE 02 02 0F 02 16 1B 09 0C 07 3F 5F 7E
7:56:51 PM
19:56:51 Get next frame.
7:56:51 PM Reading profile generic data 0.1.98.1.0.255
19:56:51 07:56:51.853 Sent 7E A0 08 02 23 03 B1 2E 76 7E
19:56:52 07:56:52.756 Received 7E A8 8C 03 00 02 00 23 5A D5 25 E4 06 1E FF 0B 36 00 FF 80 00 FF 02 03 12 0A CC 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 35 00 FF 80 00 FF 02 03 12 0A CA 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 34 00 FF 80 00 FF 02 03 12 0A C9 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 37 00 FF 80 00 FF 02 03 12 0A C8 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 33 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 05 00 00 00 00 00 09 06 60 FB 7E
7:56:52 PM
19:56:52 Get next frame.
7:56:52 PM Reading profile generic data 0.1.98.1.0.255
19:56:52 07:56:52.756 Sent 7E A0 08 02 23 03 D1 28 15 7E
19:56:53 07:56:53.725 Received 7E A8 8C 03 00 02 00 23 5C E3 40 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 49 FF 01 05 D3 4D 7E
7:56:53 PM
19:56:53 Get next frame.
7:56:53 PM Reading profile generic data 0.1.98.1.0.255
19:56:53 07:56:53.725 Sent 7E A0 08 02 23 03 F1 2A 34 7E
19:56:54 07:56:54.569 Received 7E A8 8C 03 00 02 00 23 5E F1 63 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 00 00 00 00 00 09 06 00 F0 72 7E
7:56:54 PM
19:56:54 Get next frame.
7:56:54 PM Reading profile generic data 0.1.98.1.0.255
19:56:54 07:56:54.569 Sent 7E A0 08 02 23 03 11 24 D3 7E
19:56:55 07:56:55.459 Received 7E A8 8C 03 00 02 00 23 50 8F 8A 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 64 6D 02 02 0F 02 16 1B 06 00 00 45 90 02 02 0F 02 16 1B 06 00 00 70 46 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 23 07 02 02 0F FC 16 FF 00 09 0C 07 E4 06 12 FF 03 1C 00 FF 80 00 FF 09 06 01 01 0D 04 00 FF 10 24 CB 02 02 0F FC FD A7 7E
7:56:55 PM
19:56:55 Get next frame.
7:56:55 PM Reading profile generic data 0.1.98.1.0.255
19:56:55 07:56:55.459 Sent 7E A0 08 02 23 03 31 26 F2 7E
19:56:56 07:56:56.318 Received 7E A8 8C 03 00 02 00 23 52 9D A9 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 3E 02 02 0F FE 16 2C 00 09 0C 07 E4 06 1A FF 0B 08 3B FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 A6 02 02 0F FE 16 2C 00 09 0C 07 E4 06 0D FF 02 10 37 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 01 C8 02 02 0F FE 16 21 00 09 0C 07 E4 06 1E FF 0C 0A 37 FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 01 AA 02 02 0F FE 16 21 00 68 25 7E
7:56:56 PM
19:56:56 Get next frame.
7:56:56 PM Reading profile generic data 0.1.98.1.0.255
19:56:56 07:56:56.318 Sent 7E A0 08 02 23 03 51 20 91 7E
19:56:57 07:56:57.286 Received 7E A8 8C 03 00 02 00 23 54 AB CC 09 0C 07 E4 06 1E FF 0C 19 16 FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 01 E1 02 02 0F FE 16 21 00 09 0C 07 E4 06 1E FF 0B 2F 2E FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 8C 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 06 FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 96 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 0E FF 80 00 FF 02 05 09 06 01 01 48 06 00 FF 12 09 34 1E 7E
7:56:57 PM
19:56:57 Get next frame.
7:56:57 PM Reading profile generic data 0.1.98.1.0.255
19:56:57 07:56:57.286 Sent 7E A0 08 02 23 03 71 22 B0 7E
19:56:58 07:56:58.396 Received 7E A8 8C 03 00 02 00 23 56 B9 EF 9B 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 1A FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 0A 02 02 0F 00 16 09 00 09 0C 07 E4 06 0E FF 05 1C 02 FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 24 02 02 0F 00 16 09 00 09 0C 07 E4 06 11 FF 0F 28 00 FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 13 67 F8 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 00 00 00 00 02 02 0F FF EA 87 7E
7:56:58 PM
19:56:58 Get next frame.
7:56:58 PM Reading profile generic data 0.1.98.1.0.255
19:56:58 07:56:58.396 Sent 7E A0 08 02 23 03 91 2C 57 7E
19:56:59 07:56:59.208 Received 7E A8 8C 03 00 02 00 23 58 C7 06 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 05 BB F8 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 00 00 02 02 0F 02 16 1B 4B BA 7E
7:56:59 PM
19:56:59 Get next frame.
7:56:59 PM Reading profile generic data 0.1.98.1.0.255
19:56:59 07:56:59.208 Sent 7E A0 08 02 23 03 B1 2E 76 7E
19:57:00 07:57:00.112 Received 7E A8 8C 03 00 02 00 23 5A D5 25 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 03 FF 11 77 7E
7:57:00 PM
19:57:00 Get next frame.
7:57:00 PM Reading profile generic data 0.1.98.1.0.255
19:57:00 07:57:00.112 Sent 7E A0 08 02 23 03 D1 28 15 7E
19:57:01 07:57:01.018 Received 7E A0 2C 03 00 02 00 23 5C C1 88 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 9E 5D 7E
7:57:01 PM
Attentive to your answer, greet cordially
Juan
Hi Juan,
Hi Juan,
I'm sorry, but we are little bit busy to help our clients at the moment, so I can't check this using your meter at the moment.
I check the data. There is only one row where are 66 columns. What if you try to select "All" instead of read by entry? Are you still receiving only one row?
juma
In reply to Hi Juan, by Kurumi
When I use readall I get an error message:
Access Error: Device rerports a undefined object.
Is this due to an access restriction?
Or could it be a problem with the data obtained?
Attached screenshot of the screen.
Thank you
Meter is not supporting this funtionality for this object and it's returning en error. You need to read using entry. Are you sure that you are reading the same Logical Name (0.1.98.1.0.255) with ACE Pilot?
juma
6 years 1 month ago
I send you below the trace of the ACE PILOT of a request for 5 sets of the billing profile, would it be possible to identify why this software gets all the information and the Director only the last set?
Is there a set advance question that is not implemented in the Director?
Thank you very much,
Juan
7E A0 0A 00 02 00 23 03 91 89 42 7E
7E A0 0A 03 00 02 00 23 D1 62 EC 7E
7E A0 1C 00 02 00 23 03 9C 68 74 E6 E6 00 C0 01 41 00 07 00 01 62 01 00 69 02 00 AE 5E 7E
7E A8 8C 03 00 02 00 23 E8 4C B3 E6 E7 00 C4 02 41 00 00 00 00 01 00 82 0A 99 01 05 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1E 02 02 0F 00 16 04 02 02 11 15 11 14 09 0C 07 E4 07 01 03 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 05 2D 89 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 05 08 5A 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 05 95 0B 02 02 0F 03 16 1E 02 03 09 69 E5 7E
7E A8 8C 03 00 02 00 23 EA 5E 90 06 01 01 01 08 00 FF 06 00 0F EA 52 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 02 1A 4D 02 02 0F 03 16 20 02 03 09 06 01 BE 5E 7E 7E A8 8C 03 00 02 00 23 EC 68 F5 01 2B 08 00 FF 06 00 02 52 0C 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 02 D0 45 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 07 4B 1A 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 2B F1 7E
7E A8 8C 03 00 02 00 23 EE 7A D6 08 00 FF 06 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 02 1A 4D 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 02 52 0C 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 02 D0 45 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 07 3C A0 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 5E 95 7E 7E A8 8C 03 00 02 00 23 F0 85 2F FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 2B F8 7E
7E A0 0A 00 02 00 23 03 31 83 E7 7E
7E A8 8C 03 00 02 00 23 E2 16 1C 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 05 9B CA 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 05 FC FF 7E
7E A8 8C 03 00 02 00 23 E4 20 79 8C F0 02 02 0F 03 16 1F 02 03 09 06 01 01 45 08 00 FF 06 00 06 43 9A 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 11 8E E9 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 7B 27 7E 7E A8 8C 03 00 02 00 23 E6 32 5A 02 02 0F 03 16 1F 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 97 1C 7E
7E A8 8C 03 00 02 00 23 E8 4C B3 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 DC CC 7E
7E A8 8C 03 00 02 00 23 FA DF 80 16 FF 01 01 02 04 02 05 09 06 01 01 01 08 01 FF 06 00 03 A5 BE 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 03 32 EB 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 09 11 A9 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 07 4B 1A 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 07 BD 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 33 20 AA 7E
7E A0 0A 00 02 00 23 03 D1 8D 00 7E
7E A8 8C 03 00 02 00 23 EC 68 F5 00 FF 80 00 FF 02 03 12 07 BC 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 32 00 FF 80 00 FF 02 03 12 07 BC 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 31 00 FF 80 00 FF 02 03 12 07 BB 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 34 00 FF 80 00 FF 02 03 12 07 B8 02 02 0F 02 16 1B 09 0C 07 E4 06 19 FF 12 30 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 06 33 02 02 0F 02 16 1B 09 0C BF 24 7E
7E A8 8C 03 00 02 00 23 EE 7A D6 07 E4 06 1A FF 17 04 00 FF 80 00 FF 02 03 12 06 31 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 03 00 FF 80 00 FF 02 03 12 06 30 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 05 00 FF 80 00 FF 02 03 12 06 2C 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 06 00 FF 80 00 FF 02 03 12 06 2B 02 02 0F 02 16 1B 09 0C 07 E4 06 1A FF 17 0D 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 0A CE 02 48 34 7E
7E A8 8C 03 00 02 00 23 E0 04 3F 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 36 00 FF 80 00 FF 02 03 12 0A CC 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 35 00 FF 80 00 FF 02 03 12 0A CA 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 34 00 FF 80 00 FF 02 03 12 0A C9 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 37 00 FF 80 00 FF 02 03 12 0A C8 02 02 0F 02 16 1B 09 0C 07 E4 06 1E FF 0B 33 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 69 BA 7E
7E A8 8C 03 00 02 00 23 E2 16 1C 05 00 00 00 00 00 09 06 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 AF 15 7E 7E A8 8C 03 00 02 00 23 F4 A1 69 00 00 62 85 49 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 2E B7 7E
7E A0 0A 00 02 00 23 03 71 87 A5 7E
7E A8 8C 03 00 02 00 23 E6 32 5A 00 00 00 00 00 09 06 00 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 64 6D 02 02 0F 02 16 1B 06 00 00 45 90 02 02 0F 02 16 1B 06 00 00 70 46 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 23 07 02 02 0F FC 16 FF 00 09 0C 07 E4 06 12 FF 03 1C 00 FF 80 00 FF 09 06 01 01 0D 04 00 37 E9 7E
7E A8 8C 03 00 02 00 23 E8 4C B3 FF 10 24 CB 02 02 0F FC 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 3E 02 02 0F FE 16 2C 00 09 0C 07 E4 06 1A FF 0B 08 3B FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 A6 02 02 0F FE 16 2C 00 09 0C 07 E4 06 0D FF 02 10 37 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 01 C8 02 02 0F FE 16 21 00 09 0C 07 E4 06 1E FF 0C 0A 37 FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 01 81 11 7E
7E A8 8C 03 00 02 00 23 EA 5E 90 AA 02 02 0F FE 16 21 00 09 0C 07 E4 06 1E FF 0C 19 16 FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 01 E1 02 02 0F FE 16 21 00 09 0C 07 E4 06 1E FF 0B 2F 2E FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 8C 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 06 FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 96 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 0E FF 80 00 FF 02 05 09 06 D4 D3 7E
7E A8 8C 03 00 02 00 23 EC 68 F5 01 01 48 06 00 FF 12 09 9B 02 02 0F FF 16 23 00 09 0C 07 E4 06 1C FF 03 0E 1A FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 0A 02 02 0F 00 16 09 00 09 0C 07 E4 06 0E FF 05 1C 02 FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 24 02 02 0F 00 16 09 00 09 0C 07 E4 06 11 FF 0F 28 00 FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 13 67 F8 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 A4 6F 7E
7E A8 8C 03 00 02 00 23 FE FB C6 00 00 00 00 02 02 0F FF 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 05 BB F8 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 42 3D 7E
7E A0 0A 00 02 00 23 03 11 81 C6 7E
7E A8 8C 03 00 02 00 23 E0 04 3F 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 77 3F 7E
7E A0 34 03 00 02 00 23 F2 90 AF 09 06 01 01 01 25 03 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 45 DF 7E
7E A0 16 00 02 00 23 03 5E 21 78 E6 E6 00 C0 02 41 00 00 00 01 04 34 7E
7E A8 8C 03 00 02 00 23 04 2E 9E E6 E7 00 C4 02 41 00 00 00 00 02 00 82 0A 97 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1F 02 02 0F 00 16 04 02 02 11 14 11 14 09 0C 07 E4 06 01 01 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 04 9C 43 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 04 7C AD 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 04 F5 2E 02 02 0F 03 16 1E 02 03 09 06 01 17 9D 7E 7E A8 8C 03 00 02 00 23 06 3C BD 01 01 08 00 FF 06 00 0E 2D 82 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 01 F6 DB 02 02 0F 03 16 20 02 03 09 06 01 01 2B 08 41 7E
7E A8 8C 03 00 02 00 23 08 42 54 08 00 FF 06 00 02 1D AA 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 02 8F 7F 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 06 B2 7F 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 08 00 F5 5D 7E
7E A8 8C 03 00 02 00 23 1A D1 67 FF 06 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 01 F6 DB 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 02 1D AA 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 02 8F 7F 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 06 A4 05 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 FF 06 07 8C 7E
7E A8 8C 03 00 02 00 23 0C 66 12 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 00 00 64 0A 7E
7E A8 8C 03 00 02 00 23 0E 74 31 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 05 06 17 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 04 F7 8E B6 42 7E
7E A8 8C 03 00 02 00 23 00 0A D8 02 02 0F 03 16 1F 02 03 09 06 01 01 45 08 00 FF 06 00 05 96 DB 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 0F B7 16 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 02 02 60 84 7E
7E A8 8C 03 00 02 00 23 02 18 FB 0F 03 16 1F 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 99 C6 7E 7E A8 8C 03 00 02 00 23 14 AF 8E 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF C3 F0 7E
7E A8 8C 03 00 02 00 23 06 3C BD 01 01 02 04 02 05 09 06 01 01 01 08 01 FF 06 00 03 47 B0 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 02 DE 12 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 08 07 BE 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 06 B2 7F 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 06 E2 02 02 0F 02 16 1B 09 0C 07 E4 05 1D FF 14 38 00 FF 5E 2B 7E
7E A8 8C 03 00 02 00 23 08 42 54 80 00 FF 02 03 12 06 DD 02 02 0F 02 16 1B 09 0C 07 E4 05 1D FF 14 39 00 FF 80 00 FF 02 03 12 06 DD 02 02 0F 02 16 1B 09 0C 07 E4 05 1D FF 14 37 00 FF 80 00 FF 02 03 12 06 DA 02 02 0F 02 16 1B 09 0C 07 E4 05 1D FF 14 3A 00 FF 80 00 FF 02 03 12 06 D6 02 02 0F 02 16 1B 09 0C 07 E4 05 1D FF 14 3B 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 05 F4 02 02 0F 02 16 1B 09 0C 07 E4 2F 1C 7E
7E A8 8C 03 00 02 00 23 0A 50 77 05 1E FF 17 01 00 FF 80 00 FF 02 03 12 05 EF 02 02 0F 02 16 1B 09 0C 07 E4 05 1E FF 17 02 00 FF 80 00 FF 02 03 12 05 ED 02 02 0F 02 16 1B 09 0C 07 E4 05 14 FF 17 01 00 FF 80 00 FF 02 03 12 05 EB 02 02 0F 02 16 1B 09 0C 07 E4 05 14 FF 17 03 00 FF 80 00 FF 02 03 12 05 EB 02 02 0F 02 16 1B 09 0C 07 E4 05 14 FF 17 02 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 09 0E 02 02 0F 26 1D 7E
7E A8 8C 03 00 02 00 23 0C 66 12 02 16 1B 09 0C 07 E4 05 1A FF 0C 24 00 FF 80 00 FF 02 03 12 09 0B 02 02 0F 02 16 1B 09 0C 07 E4 05 1A FF 0C 2C 00 FF 80 00 FF 02 03 12 09 0B 02 02 0F 02 16 1B 09 0C 07 E4 05 1A FF 0C 25 00 FF 80 00 FF 02 03 12 09 09 02 02 0F 02 16 1B 09 0C 07 E4 05 1A FF 0C 23 00 FF 80 00 FF 02 03 12 09 07 02 02 0F 02 16 1B 09 0C 07 E4 05 1A FF 0C 2B 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 05 00 0E A5 7E 7E A8 8C 03 00 02 00 23 1E F5 21 00 00 00 00 09 06 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 00 00 0B 65 7E
7E A8 8C 03 00 02 00 23 00 0A D8 62 85 49 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 00 00 07 97 7E
7E A8 8C 03 00 02 00 23 02 18 FB 00 00 00 09 06 00 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 5C B0 02 02 0F 02 16 1B 06 00 00 3F 5D 02 02 0F 02 16 1B 06 00 00 65 78 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 22 62 02 02 0F FC 16 FF 00 09 0C 07 E4 05 0A FF 0F 06 00 FF 80 00 FF 09 06 01 01 0D 04 00 FF 10 C9 5A 7E 7E A8 8C 03 00 02 00 23 04 2E 9E 24 2C 02 02 0F FC 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 43 02 02 0F FE 16 2C 00 09 0C 07 E4 05 03 FF 10 22 00 FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 A6 02 02 0F FE 16 2C 00 09 0C 07 E4 05 0F FF 06 33 04 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 01 7C 02 02 0F FE 16 21 00 09 0C 07 E4 05 1D FF 0C 37 35 FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 01 80 02 51 1B 7E
7E A8 8C 03 00 02 00 23 06 3C BD 02 0F FE 16 21 00 09 0C 07 E4 05 1D FF 0C 1E 2A FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 02 17 02 02 0F FE 16 21 00 09 0C 07 E4 05 13 FF 11 08 2B FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 85 02 02 0F FF 16 23 00 09 0C 07 E4 05 13 FF 11 0A 04 FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 88 02 02 0F FF 16 23 00 09 0C 07 E4 05 19 FF 16 0D 37 FF 80 00 FF 02 05 09 06 01 01 6F 90 7E 7E A8 8C 03 00 02 00 23 18 C3 44 48 06 00 FF 12 09 94 02 02 0F FF 16 23 00 09 0C 07 E4 05 13 FF 11 09 3A FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 0D 02 02 0F 00 16 09 00 09 0C 07 E4 05 0E FF 06 19 2B FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 25 02 02 0F 00 16 09 00 09 0C 07 E4 05 10 FF 0F 23 3A FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 14 35 D4 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 00 00 D7 F8 7E
7E A0 0A 00 02 00 23 03 B1 8B 63 7E
7E A8 8C 03 00 02 00 23 0A 50 77 00 00 02 02 0F FF 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 07 12 8C 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 00 00 7D 5A 7E
7E A8 8C 03 00 02 00 23 0C 66 12 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 86 29 7E
7E A0 32 03 00 02 00 23 1E 3F DA 01 01 01 25 03 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 06 11 7E
7E A0 16 00 02 00 23 03 10 5B D3 E6 E6 00 C0 02 41 00 00 00 02 9F 06 7E
7E A8 8C 03 00 02 00 23 20 08 F9 E6 E7 00 C4 02 41 00 00 00 00 03 00 82 0A 97 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1E 02 02 0F 00 16 04 02 02 11 13 11 14 09 0C 07 E4 05 01 05 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 04 11 28 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 03 F2 91 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 04 58 FD 02 02 0F 03 16 1E 02 03 09 06 01 19 87 7E
7E A8 8C 03 00 02 00 23 22 1A DA 01 01 08 00 FF 06 00 0C 7C 1A 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 01 CE 7C 02 02 0F 03 16 20 02 03 09 06 01 01 2B 63 DE 7E
7E A8 8C 03 00 02 00 23 34 AD AF 08 00 FF 06 00 01 E2 34 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 02 47 A5 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 06 06 D1 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 08 00 68 FF 7E
7E A8 8C 03 00 02 00 23 26 3E 9C FF 06 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 01 CE 7C 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 01 E2 34 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 02 47 A5 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 05 F8 56 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 FF 06 F3 70 7E
7E A8 8C 03 00 02 00 23 28 40 75 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 00 00 64 0A 7E
7E A8 8C 03 00 02 00 23 2A 52 56 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 04 75 09 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 04 61 04 37 A1 7E
7E A8 8C 03 00 02 00 23 2C 64 33 02 02 0F 03 16 1F 02 03 09 06 01 01 45 08 00 FF 06 00 04 EA A9 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 0D E3 4B 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 02 02 9B C9 7E 7E A8 8C 03 00 02 00 23 3E F7 00 0F 03 16 1F 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 99 C6 7E
7E A8 8C 03 00 02 00 23 20 08 F9 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF C3 F0 7E
7E A8 8C 03 00 02 00 23 22 1A DA 01 01 02 04 02 05 09 06 01 01 01 08 01 FF 06 00 02 E9 74 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 02 83 A8 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 07 0E FD 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 06 06 D1 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 06 D6 02 02 0F 02 16 1B 09 0C 07 E4 04 01 FF 14 2A 00 FF 7E 07 7E
7E A8 8C 03 00 02 00 23 24 2C BF 80 00 FF 02 03 12 06 D2 02 02 0F 02 16 1B 09 0C 07 E4 04 01 FF 14 29 00 FF 80 00 FF 02 03 12 06 D1 02 02 0F 02 16 1B 09 0C 07 E4 04 01 FF 14 2B 00 FF 80 00 FF 02 03 12 06 CB 02 02 0F 02 16 1B 09 0C 07 E4 04 01 FF 14 28 00 FF 80 00 FF 02 03 12 06 CA 02 02 0F 02 16 1B 09 0C 07 E4 04 17 FF 14 14 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 06 0E 02 02 0F 02 16 1B 09 0C 07 E4 76 A9 7E
7E A8 8C 03 00 02 00 23 26 3E 9C 04 0E FF 17 06 00 FF 80 00 FF 02 03 12 06 0D 02 02 0F 02 16 1B 09 0C 07 E4 04 0E FF 17 07 00 FF 80 00 FF 02 03 12 06 0B 02 02 0F 02 16 1B 09 0C 07 E4 04 0E FF 17 05 00 FF 80 00 FF 02 03 12 06 08 02 02 0F 02 16 1B 09 0C 07 E4 04 0E FF 17 08 00 FF 80 00 FF 02 03 12 06 07 02 02 0F 02 16 1B 09 0C 07 E4 04 0E FF 17 04 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 07 E9 02 02 0F 1B 6C 7E 7E A8 8C 03 00 02 00 23 38 C1 65 02 16 1B 09 0C 07 E4 04 1C FF 0D 10 00 FF 80 00 FF 02 03 12 07 E8 02 02 0F 02 16 1B 09 0C 07 E4 04 1C FF 0D 11 00 FF 80 00 FF 02 03 12 07 E3 02 02 0F 02 16 1B 09 0C 07 E4 04 1C FF 0D 12 00 FF 80 00 FF 02 03 12 07 E3 02 02 0F 02 16 1B 09 0C 07 E4 04 1C FF 0D 0F 00 FF 80 00 FF 02 03 12 07 E2 02 02 0F 02 16 1B 09 0C 07 E4 04 1C FF 0D 0E 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 05 00 28 19 7E
7E A8 8C 03 00 02 00 23 2A 52 56 00 00 00 00 09 06 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 00 00 0B 65 7E
7E A8 8C 03 00 02 00 23 2C 64 33 62 85 49 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 00 00 07 97 7E
7E A8 8C 03 00 02 00 23 2E 76 10 00 00 00 09 06 00 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 55 CE 02 02 0F 02 16 1B 06 00 00 39 69 02 02 0F 02 16 1B 06 00 00 5C 6A 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 21 B8 02 02 0F FC 16 FF 00 09 0C 07 E4 04 01 FF 04 37 00 FF 80 00 FF 09 06 01 01 0D 04 00 FF 10 64 45 7E 7E A8 8C 03 00 02 00 23 20 08 F9 23 81 02 02 0F FC 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 71 02 02 0F FE 16 2C 00 09 0C 07 E4 04 1C FF 07 14 34 FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 A1 02 02 0F FE 16 2C 00 09 0C 07 E4 04 04 FF 07 0B 02 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 01 4B 02 02 0F FE 16 21 00 09 0C 07 E4 04 0F FF 0C 18 2D FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 01 7C 02 55 9E 7E
7E A8 8C 03 00 02 00 23 32 9B CA 02 0F FE 16 21 00 09 0C 07 E4 04 1C FF 0D 03 25 FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 01 84 02 02 0F FE 16 21 00 09 0C 07 E4 04 0E FF 15 14 36 FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 75 02 02 0F FF 16 23 00 09 0C 07 E4 04 0C FF 07 09 04 FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 7F 02 02 0F FF 16 23 00 09 0C 07 E4 04 10 FF 07 19 2C FF 80 00 FF 02 05 09 06 01 01 39 F7 7E
7E A0 0A 00 02 00 23 03 51 85 84 7E
7E A8 8C 03 00 02 00 23 24 2C BF 48 06 00 FF 12 09 81 02 02 0F FF 16 23 00 09 0C 07 E4 04 0C FF 07 09 05 FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 10 02 02 0F 00 16 09 00 09 0C 07 E4 04 07 FF 07 1F 1C FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 2A 02 02 0F 00 16 09 00 09 0C 07 E4 04 14 FF 11 1C 02 FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 14 16 94 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 00 00 FA E3 7E
7E A8 8C 03 00 02 00 23 26 3E 9C 00 00 02 02 0F FF 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 09 48 F4 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 00 00 18 67 7E
7E A8 8C 03 00 02 00 23 28 40 75 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 86 29 7E 7E A0 32 03 00 02 00 23 3A 19 BD 01 01 01 25 03 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 06 11 7E
7E A0 16 00 02 00 23 03 D2 45 36 E6 E6 00 C0 02 41 00 00 00 03 16 17 7E
7E A8 8C 03 00 02 00 23 4C 62 50 E6 E7 00 C4 02 41 00 00 00 00 04 00 82 0A 97 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1F 02 02 0F 00 16 04 02 02 11 12 11 14 09 0C 07 E4 04 01 03 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 03 93 4E 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 03 6B F6 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 03 C7 11 02 02 0F 03 16 1E 02 03 09 06 01 F7 21 7E
7E A8 8C 03 00 02 00 23 5E F1 63 01 01 08 00 FF 06 00 0A E5 B9 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 01 A1 AC 02 02 0F 03 16 20 02 03 09 06 01 01 2B 8A EE 7E
7E A8 8C 03 00 02 00 23 40 0E 9A 08 00 FF 06 00 01 A3 8B 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 01 FB 54 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 05 4F 07 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 08 00 9A 96 7E
7E A8 8C 03 00 02 00 23 42 1C B9 FF 06 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 01 A1 AC 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 01 A3 8B 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 01 FB 54 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 05 40 8D 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 FF 06 EF 05 7E
7E A8 8C 03 00 02 00 23 44 2A DC 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 00 00 64 0A 7E
7E A8 8C 03 00 02 00 23 46 38 FF 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 03 EF 4E 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 03 CC 65 BD FA 7E 7E A8 8C 03 00 02 00 23 58 C7 06 02 02 0F 03 16 1F 02 03 09 06 01 01 45 08 00 FF 06 00 04 45 C8 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 0C 24 11 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 02 02 DB 27 7E
7E A8 8C 03 00 02 00 23 4A 54 35 0F 03 16 1F 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 99 C6 7E
7E A8 8C 03 00 02 00 23 4C 62 50 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF C3 F0 7E
7E A8 8C 03 00 02 00 23 4E 70 73 01 01 02 04 02 05 09 06 01 01 01 08 01 FF 06 00 02 90 36 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 02 2B 37 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 06 2A 4A 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 05 4F 07 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 0F 33 02 02 0F 02 16 1B 09 0C 07 E4 03 04 FF 12 07 00 FF E0 D9 7E 7E A8 8C 03 00 02 00 23 40 0E 9A 80 00 FF 02 03 12 0F 33 02 02 0F 02 16 1B 09 0C 07 E4 03 04 FF 12 06 00 FF 80 00 FF 02 03 12 0F 31 02 02 0F 02 16 1B 09 0C 07 E4 03 04 FF 12 08 00 FF 80 00 FF 02 03 12 0F 2B 02 02 0F 02 16 1B 09 0C 07 E4 03 04 FF 12 09 00 FF 80 00 FF 02 03 12 0F 2A 02 02 0F 02 16 1B 09 0C 07 E4 03 04 FF 12 05 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 09 D4 02 02 0F 02 16 1B 09 0C 07 E4 FA 30 7E
7E A8 8C 03 00 02 00 23 52 9D A9 03 07 FF 17 37 00 FF 80 00 FF 02 03 12 09 D3 02 02 0F 02 16 1B 09 0C 07 E4 03 07 FF 17 38 00 FF 80 00 FF 02 03 12 09 CE 02 02 0F 02 16 1B 09 0C 07 E4 03 07 FF 17 36 00 FF 80 00 FF 02 03 12 09 CB 02 02 0F 02 16 1B 09 0C 07 E4 03 07 FF 17 39 00 FF 80 00 FF 02 03 12 09 C3 02 02 0F 02 16 1B 09 0C 07 E4 03 07 FF 17 3A 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 10 0D 02 02 0F BD 29 7E
7E A8 8C 03 00 02 00 23 44 2A DC 02 16 1B 09 0C 07 E4 03 02 FF 0C 09 00 FF 80 00 FF 02 03 12 10 0A 02 02 0F 02 16 1B 09 0C 07 E4 03 02 FF 0C 08 00 FF 80 00 FF 02 03 12 10 07 02 02 0F 02 16 1B 09 0C 07 E4 03 02 FF 0C 0A 00 FF 80 00 FF 02 03 12 10 06 02 02 0F 02 16 1B 09 0C 07 E4 03 02 FF 0B 29 00 FF 80 00 FF 02 03 12 10 05 02 02 0F 02 16 1B 09 0C 07 E4 03 02 FF 0C 07 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 05 00 A5 AF 7E
7E A8 8C 03 00 02 00 23 46 38 FF 00 00 00 00 09 06 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 00 00 0B 65 7E
7E A8 8C 03 00 02 00 23 48 46 16 62 85 49 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 00 00 07 97 7E
7E A8 8C 03 00 02 00 23 4A 54 35 00 00 00 09 06 00 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 4E F8 02 02 0F 02 16 1B 06 00 00 33 5B 02 02 0F 02 16 1B 06 00 00 54 81 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 20 E5 02 02 0F FC 16 FF 00 09 0C 07 E4 03 16 FF 07 16 00 FF 80 00 FF 09 06 01 01 0D 04 00 FF 10 19 22 7E 7E A8 8C 03 00 02 00 23 5C E3 40 22 F0 02 02 0F FC 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 19 02 02 0F FE 16 2C 00 09 0C 07 E4 03 05 FF 10 3B 05 FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 B9 02 02 0F FE 16 2C 00 09 0C 07 E4 03 0E FF 0E 33 11 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 02 D2 02 02 0F FE 16 21 00 09 0C 07 E4 03 02 FF 0B 1B 28 FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 02 A2 02 07 8E 7E
7E A0 0A 00 02 00 23 03 F1 8F 21 7E
7E A8 8C 03 00 02 00 23 4E 70 73 02 0F FE 16 21 00 09 0C 07 E4 03 04 FF 11 36 1B FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 02 DA 02 02 0F FE 16 21 00 09 0C 07 E4 03 03 FF 0B 1F 27 FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 7E 02 02 0F FF 16 23 00 09 0C 07 E4 03 1A FF 03 04 38 FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 8E 02 02 0F FF 16 23 00 09 0C 07 E4 03 1A FF 03 04 36 FF 80 00 FF 02 05 09 06 01 01 18 45 7E
7E A8 8C 03 00 02 00 23 40 0E 9A 48 06 00 FF 12 09 76 02 02 0F FF 16 23 00 09 0C 07 E4 03 11 FF 16 2F 1C FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 16 02 02 0F 00 16 09 00 09 0C 07 E4 03 10 FF 07 16 07 FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 31 02 02 0F 00 16 09 00 09 0C 07 E4 03 04 FF 10 2B 21 FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 14 C7 24 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 00 00 9B EC 7E
7E A8 8C 03 00 02 00 23 42 1C B9 00 00 02 02 0F FF 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 0A 34 80 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 00 00 9E DA 7E
7E A8 8C 03 00 02 00 23 44 2A DC 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 86 29 7E 7E A0 32 03 00 02 00 23 56 73 14 01 01 01 25 03 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 06 11 7E
7E A0 16 00 02 00 23 03 94 77 11 E6 E6 00 C0 02 41 00 00 00 04 A9 63 7E
7E A8 8C 03 00 02 00 23 78 C5 27 E6 E7 00 C4 02 41 01 00 00 00 05 00 82 0A 97 02 42 02 05 09 06 01 00 62 86 01 FF 12 00 1D 02 02 0F 00 16 04 02 02 11 11 11 14 09 0C 07 E4 03 01 00 00 01 00 FF 80 00 FF 01 01 02 34 02 03 09 06 01 01 15 08 00 FF 06 00 02 DA D1 02 02 0F 03 16 1E 02 03 09 06 01 01 29 08 00 FF 06 00 02 AF 5B 02 02 0F 03 16 1E 02 03 09 06 01 01 3D 08 00 FF 06 00 02 FD 75 02 02 0F 03 16 1E 02 03 09 06 01 C4 CB 7E
7E A8 8C 03 00 02 00 23 6A 56 14 01 01 08 00 FF 06 00 08 A7 04 02 02 0F 03 16 1E 02 03 09 06 01 01 16 08 00 FF 06 00 00 10 0A 02 02 0F 03 16 1E 02 03 09 06 01 01 2A 08 00 FF 06 00 00 0F 57 02 02 0F 03 16 1E 02 03 09 06 01 01 3E 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 01 02 08 00 FF 06 00 00 1F 62 02 02 0F 03 16 1E 02 03 09 06 01 01 17 08 00 FF 06 00 01 50 3B 02 02 0F 03 16 20 02 03 09 06 01 01 2B 6B 58 7E
7E A8 8C 03 00 02 00 23 6C 60 71 08 00 FF 06 00 01 47 27 02 02 0F 03 16 20 02 03 09 06 01 01 3F 08 00 FF 06 00 01 90 9F 02 02 0F 03 16 20 02 03 09 06 01 01 03 08 00 FF 06 00 04 36 7D 02 02 0F 03 16 20 02 03 09 06 01 01 18 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2C 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 40 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 04 08 00 EA D1 7E
7E A8 8C 03 00 02 00 23 6E 72 52 FF 06 00 00 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 19 08 00 FF 06 00 01 50 3B 02 02 0F 03 16 20 02 03 09 06 01 01 2D 08 00 FF 06 00 01 47 27 02 02 0F 03 16 20 02 03 09 06 01 01 41 08 00 FF 06 00 01 90 9F 02 02 0F 03 16 20 02 03 09 06 01 01 05 08 00 FF 06 00 04 28 02 02 02 0F 03 16 20 02 03 09 06 01 01 1A 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 2E 08 00 FF 06 DC 6B 7E
7E A8 8C 03 00 02 00 23 60 0C BB 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 42 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 06 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1B 08 00 FF 06 00 00 07 6F 02 02 0F 03 16 20 02 03 09 06 01 01 2F 08 00 FF 06 00 00 07 0A 02 02 0F 03 16 20 02 03 09 06 01 01 43 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 07 08 00 FF 06 00 00 64 0A 7E 7E A8 8C 03 00 02 00 23 72 9F 88 0E 7A 02 02 0F 03 16 20 02 03 09 06 01 01 1C 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 30 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 44 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 08 08 00 FF 06 00 00 00 00 02 02 0F 03 16 20 02 03 09 06 01 01 1D 08 00 FF 06 00 03 25 73 02 02 0F 03 16 1F 02 03 09 06 01 01 31 08 00 FF 06 00 02 FA 33 F3 81 7E
7E A8 8C 03 00 02 00 23 64 28 FD 02 02 0F 03 16 1F 02 03 09 06 01 01 45 08 00 FF 06 00 03 61 5B 02 02 0F 03 16 1F 02 03 09 06 01 01 09 08 00 FF 06 00 09 A3 97 02 02 0F 03 16 1F 02 03 09 06 01 01 1E 08 00 FF 06 00 00 11 B0 02 02 0F 03 16 1F 02 03 09 06 01 01 32 08 00 FF 06 00 00 10 E3 02 02 0F 03 16 1F 02 03 09 06 01 01 46 08 00 FF 06 00 00 00 00 02 02 0F 03 16 1F 02 03 09 06 01 01 0A 08 00 FF 06 00 00 22 94 02 02 1B 8E 7E
7E A8 8C 03 00 02 00 23 66 3A DE 0F 03 16 1F 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 02 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 03 52 08 00 FF 06 00 00 00 00 02 02 0F 00 99 C6 7E
7E A8 8C 03 00 02 00 23 68 44 37 16 FF 02 03 09 06 01 04 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 05 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 06 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 07 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 08 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF 02 03 09 06 01 09 52 08 00 FF 06 00 00 00 00 02 02 0F 00 16 FF C3 F0 7E
7E A8 8C 03 00 02 00 23 6A 56 14 01 01 02 04 02 05 09 06 01 01 01 08 01 FF 06 00 02 0B 44 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 02 FF 06 00 01 B5 56 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 01 08 03 FF 06 00 04 E6 69 02 02 0F 03 16 1E 00 00 02 05 09 06 01 01 03 08 01 FF 06 00 04 36 7D 02 02 0F 03 16 20 00 00 09 06 00 00 62 85 3D FF 01 05 02 03 12 10 51 02 02 0F 02 16 1B 09 0C 07 E4 02 03 FF 12 1C 00 FF 6A D2 7E 7E A8 8C 03 00 02 00 23 7C E1 61 80 00 FF 02 03 12 10 50 02 02 0F 02 16 1B 09 0C 07 E4 02 03 FF 12 1B 00 FF 80 00 FF 02 03 12 10 4B 02 02 0F 02 16 1B 09 0C 07 E4 02 03 FF 12 1A 00 FF 80 00 FF 02 03 12 10 49 02 02 0F 02 16 1B 09 0C 07 E4 02 03 FF 12 1D 00 FF 80 00 FF 02 03 12 10 43 02 02 0F 02 16 1B 09 0C 07 E4 02 03 FF 12 1E 00 FF 80 00 FF 09 06 00 00 62 85 3E FF 01 05 02 03 12 0B 22 02 02 0F 02 16 1B 09 0C 07 E4 F1 41 7E
7E A8 8C 03 00 02 00 23 6E 72 52 02 06 FF 17 01 00 FF 80 00 FF 02 03 12 0B 13 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 17 02 00 FF 80 00 FF 02 03 12 0B 07 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 17 03 00 FF 80 00 FF 02 03 12 0A FA 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 17 04 00 FF 80 00 FF 02 03 12 0A EE 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 17 05 00 FF 80 00 FF 09 06 00 00 62 85 3F FF 01 05 02 03 12 12 CC 02 02 0F 24 4A 7E
7E A8 8C 03 00 02 00 23 60 0C BB 02 16 1B 09 0C 07 E4 02 06 FF 0C 1D 00 FF 80 00 FF 02 03 12 12 CB 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 0C 1E 00 FF 80 00 FF 02 03 12 12 C7 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 0C 1F 00 FF 80 00 FF 02 03 12 12 C6 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 0C 1C 00 FF 80 00 FF 02 03 12 12 BE 02 02 0F 02 16 1B 09 0C 07 E4 02 06 FF 0C 1B 00 FF 80 00 FF 09 06 00 00 62 85 40 FF 01 05 00 03 CB 7E
7E A8 8C 03 00 02 00 23 62 1E 98 00 00 00 00 09 06 00 00 62 85 41 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 42 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 43 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 44 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 45 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 46 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 47 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 48 FF 01 05 00 00 00 00 00 09 06 00 00 0B 65 7E
7E A8 8C 03 00 02 00 23 64 28 FD 62 85 49 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4A FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4B FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4C FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4D FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4E FF 01 05 00 00 00 00 00 09 06 00 00 62 85 4F FF 01 05 00 00 00 00 00 09 06 00 00 62 85 50 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 51 FF 01 05 00 00 07 97 7E 7E A8 8C 03 00 02 00 23 76 BB CE 00 00 00 09 06 00 00 62 85 52 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 53 FF 01 05 00 00 00 00 00 09 06 00 00 62 85 54 FF 01 05 00 00 00 00 00 01 01 02 06 06 00 00 3F C5 02 02 0F 02 16 1B 06 00 00 29 87 02 02 0F 02 16 1B 06 00 00 44 74 02 02 0F 02 16 1B 02 05 09 06 01 01 0D 03 00 FF 10 20 CA 02 02 0F FC 16 FF 00 09 0C 07 E4 02 11 FF 07 0A 00 FF 80 00 FF 09 06 01 01 0D 04 00 FF 10 DD EF 7E
7E A8 8C 03 00 02 00 23 68 44 37 22 F4 02 02 0F FC 16 FF 02 05 09 06 01 01 0E 03 00 FF 12 13 66 02 02 0F FE 16 2C 00 09 0C 07 E4 02 0A FF 06 3A 33 FF 80 00 FF 02 05 09 06 01 01 0E 06 00 FF 12 13 A4 02 02 0F FE 16 2C 00 09 0C 07 E4 02 14 FF 05 2B 00 FF 80 00 FF 01 01 02 06 02 05 09 06 01 01 1F 06 00 FF 12 03 23 02 02 0F FE 16 21 00 09 0C 07 E4 02 06 FF 0C 0B 18 FF 80 00 FF 02 05 09 06 01 01 33 06 00 FF 12 02 D8 02 E1 ED 7E
7E A8 8C 03 00 02 00 23 6A 56 14 02 0F FE 16 21 00 09 0C 07 E4 02 06 FF 0B 0A 3B FF 80 00 FF 02 05 09 06 01 01 47 06 00 FF 12 03 39 02 02 0F FE 16 21 00 09 0C 07 E4 02 06 FF 0B 35 1E FF 80 00 FF 02 05 09 06 01 01 20 06 00 FF 12 09 B2 02 02 0F FF 16 23 00 09 0C 07 E4 02 14 FF 11 16 3B FF 80 00 FF 02 05 09 06 01 01 34 06 00 FF 12 09 B8 02 02 0F FF 16 23 00 09 0C 07 E4 02 14 FF 11 16 3B FF 80 00 FF 02 05 09 06 01 01 B2 C0 7E
7E A8 8C 03 00 02 00 23 6C 60 71 48 06 00 FF 12 09 B5 02 02 0F FF 16 23 00 09 0C 07 E4 02 14 FF 11 16 3B FF 80 00 FF 02 05 09 06 00 00 80 03 00 FF 0F 13 02 02 0F 00 16 09 00 09 0C 07 E4 02 16 FF 07 2B 1C FF 80 00 FF 02 05 09 06 00 00 80 06 00 FF 0F 32 02 02 0F 00 16 09 00 09 0C 07 E4 02 02 FF 11 17 35 FF 80 00 FF 02 03 09 06 01 01 01 07 00 FF 06 00 20 40 40 02 02 0F FF 16 1B 02 03 09 06 01 01 02 07 00 FF 06 00 00 63 AC 7E
7E A8 8C 03 00 02 00 23 6E 72 52 00 00 02 02 0F FF 16 1B 02 03 09 06 01 01 03 07 00 FF 06 00 0F DA 98 02 02 0F FF 16 1D 02 03 09 06 01 01 04 07 00 FF 06 00 00 00 00 02 02 0F FF 16 1D 01 01 02 0C 02 03 09 06 01 01 01 23 01 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 01 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 01 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 01 FF 06 00 00 00 00 90 C5 7E 7E A8 8C 03 00 02 00 23 70 8D AB 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 02 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 02 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 01 01 01 25 02 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 02 FF 06 00 00 00 00 02 02 0F 02 16 1B 02 03 09 06 01 01 01 23 03 FF 12 FF FF 02 02 0F 02 16 1B 02 03 09 06 01 01 01 24 03 FF 12 00 00 02 02 0F 00 16 FF 02 03 09 06 86 29 7E
7E A0 32 03 00 02 00 23 72 55 73 01 01 01 25 03 FF 06 00 00 00 00 02 02 0F 00 16 06 02 03 09 06 01 01 01 26 03 FF 06 00 00 00 00 02 02 0F 02 16 1B 06 11 7E
7E A0 1C 00 02 00 23 03 56 3E 1D E6 E6 00 C0 01 41 00 07 00 00 62 85 3D FF 03 00 3B E7 7E
7E A0 4B 03 00 02 00 23 94 18 A1 E6 E7 00 C4 01 41 00 01 03 02 04 12 00 04 09 06 01 01 01 06 01 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 01 01 06 01 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 01 01 06 01 FF 0F 05 12 00 00 2D 17 7E
7E A0 1C 00 02 00 23 03 78 42 D5 E6 E6 00 C0 01 41 00 07 00 00 62 85 3E FF 03 00 F6 C2 7E
7E A0 4B 03 00 02 00 23 B6 08 A3 E6 E7 00 C4 01 41 00 01 03 02 04 12 00 04 09 06 01 01 01 06 02 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 01 01 06 02 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 01 01 06 02 FF 0F 05 12 00 00 82 03 7E
7E A0 1C 00 02 00 23 03 9A 5E 11 E6 E6 00 C0 01 41 00 07 00 00 62 85 3F FF 03 00 4D DE 7E
7E A0 4B 03 00 02 00 23 D8 70 29 E6 E7 00 C4 01 41 00 01 03 02 04 12 00 04 09 06 01 01 01 06 03 FF 0F 02 12 00 00 02 04 12 00 04 09 06 01 01 01 06 03 FF 0F 03 12 00 00 02 04 12 00 04 09 06 01 01 01 06 03 FF 0F 05 12 00 00 E8 F7 7E
7E A0 1C 00 02 00 23 03 BC 6A 55 E6 E6 00 C0 01 41 00 07 00 00 62 85 40 FF 03 00 F1 36 7E
7E A0 15 03 00 02 00 23 FA 8E DF E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 DE 7E 15 E6 E6 00 C0 01 41 00 07 00 00 62 85 41 FF 03 00 4A 2A 7E
7E A0 15 03 00 02 00 23 1C B6 5D E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 F0 02 DD E6 E6 00 C0 01 41 00 07 00 00 62 85 42 FF 03 00 87 0F 7E
7E A0 15 03 00 02 00 23 3E A6 5F E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 12 1E 19 E6 E6 00 C0 01 41 00 07 00 00 62 85 43 FF 03 00 3C 13 7E
7E A0 15 03 00 02 00 23 50 DE D5 E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 34 2A 5D E6 E6 00 C0 01 41 00 07 00 00 62 85 44 FF 03 00 1D 44 7E
7E A0 15 03 00 02 00 23 72 CE D7 E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 56 3E 1D E6 E6 00 C0 01 41 00 07 00 00 62 85 45 FF 03 00 A6 58 7E
7E A0 15 03 00 02 00 23 94 F6 55 E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 78 42 D5 E6 E6 00 C0 01 41 00 07 00 00 62 85 46 FF 03 00 6B 7D 7E
7E A0 15 03 00 02 00 23 B6 E6 57 E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 9A 5E 11 E6 E6 00 C0 01 41 00 07 00 00 62 85 47 FF 03 00 D0 61 7E
7E A0 15 03 00 02 00 23 D8 9E DD E6 E7 00 C4 01 41 00 01 00 E4 F5 7E
7E A0 1C 00 02 00 23 03 BC 6A 55 E6 E6 00 C0 01 41 00 07 00 00 62 85 48 FF 03 00 29 D3 7E
7E A0 1C 00 02 00 23 03 DE 7E 15 E6 E6 00 C0 01 41 00 07 00 00 62 85 49 FF 03 00 92 CF 7E
7E A0 1C 00 02 00 23 03 F0 02 DD E6 E6 00 C0 01 41 00 07 00 00 62 85 4A FF 03 00 5F EA 7E
7E A0 1C 00 02 00 23 03 12 1E 19 E6 E6 00 C0 01 41 00 07 00 00 62 85 4B FF 03 00 E4 F6 7E
7E A0 1C 00 02 00 23 03 34 2A 5D E6 E6 00 C0 01 41 00 07 00 00 62 85 4C FF 03 00 C5 A1 7E
7E A0 1C 00 02 00 23 03 56 3E 1D E6 E6 00 C0 01 41 00 07 00 00 62 85 4D FF 03 00 7E BD 7E
7E A0 1C 00 02 00 23 03 78 42 D5 E6 E6 00 C0 01 41 00 07 00 00 62 85 4E FF 03 00 B3 98 7E
7E A0 1C 00 02 00 23 03 9A 5E 11 E6 E6 00 C0 01 41 00 07 00 00 62 85 4F FF 03 00 08 84 7E
7E A0 1C 00 02 00 23 03 BC 6A 55 E6 E6 00 C0 01 41 00 07 00 00 62 85 50 FF 03 00 50 F5 7E
7E A0 1C 00 02 00 23 03 DE 7E 15 E6 E6 00 C0 01 41 00 07 00 00 62 85 51 FF 03 00 EB E9 7E
7E A0 1C 00 02 00 23 03 F0 02 DD E6 E6 00 C0 01 41 00 07 00 00 62 85 52 FF 03 00 26 CC 7E
7E A0 1C 00 02 00 23 03 12 1E 19 E6 E6 00 C0 01 41 00 07 00 00 62 85 53 FF 03 00 9D D0 7E
7E A0 1C 00 02 00 23 03 34 2A 5D E6 E6 00 C0 01 41 00 07 00 00 62 85 54 FF 03 00 BC 87 7E
7E A0 1C 00 02 00 23 03 56 3E 1D E6 E6 00 C0 01 41 00 07 00 00 62 85 5A FF 03 00 FE 29 7E
7E A0 81 03 00 02 00 23 94 54 09 E6 E7 00 C4 01 41 00 01 06 02 04 12 00 03 09 06 01 01 01 02 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 02 01 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 01 01 02 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 02 02 FF 0F 03 12 00 00 02 04 12 00 03 09 06 01 01 01 02 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 02 03 FF 0F 03 12 00 00 E6 6C 7E
7E A0 1C 00 02 00 23 03 78 42 D5 E6 E6 00 C0 01 41 00 15 01 00 01 05 00 FF 03 00 0E C4 7E
7E A0 22 03 00 02 00 23 B6 B4 46 E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 9A 5E 11 E6 E6 00 C0 01 41 00 15 01 00 01 05 01 FF 03 00 B5 D8 7E
7E A0 22 03 00 02 00 23 D8 CC CC E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 BC 6A 55 E6 E6 00 C0 01 41 00 15 01 00 01 05 02 FF 03 00 78 FD 7E
7E A0 22 03 00 02 00 23 FA DC CE E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 DE 7E 15 E6 E6 00 C0 01 41 00 15 01 00 01 05 03 FF 03 00 C3 E1 7E
7E A0 22 03 00 02 00 23 1C E4 4C E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 F0 02 DD E6 E6 00 C0 01 41 00 15 01 00 01 05 04 FF 03 00 E2 B6 7E
7E A0 22 03 00 02 00 23 3E F4 4E E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 12 1E 19 E6 E6 00 C0 01 41 00 15 01 00 01 05 05 FF 03 00 59 AA 7E
7E A0 22 03 00 02 00 23 50 8C C4 E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 34 2A 5D E6 E6 00 C0 01 41 00 15 01 00 01 05 06 FF 03 00 94 8F 7E
7E A0 22 03 00 02 00 23 72 9C C6 E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 56 3E 1D E6 E6 00 C0 01 41 00 15 01 00 01 05 07 FF 03 00 2F 93 7E
7E A0 22 03 00 02 00 23 94 A4 44 E6 E7 00 C4 01 41 00 02 03 12 00 05 09 06 FF FF FF FF FF FF 0F 03 76 A8 7E
7E A0 1C 00 02 00 23 03 78 42 D5 E6 E6 00 C0 01 41 00 15 01 00 01 05 08 FF 03 00 D6 21 7E
7E A0 1C 00 02 00 23 03 9A 5E 11 E6 E6 00 C0 01 41 00 15 01 00 01 05 09 FF 03 00 6D 3D 7E
7E A0 1C 00 02 00 23 03 BC 6A 55 E6 E6 00 C0 01 41 00 07 01 01 62 02 03 69 02 00 10 E7 7E
7E A8 8C 03 00 02 00 23 EA 5E 90 E6 E7 00 C4 02 41 00 00 00 00 01 00 82 03 6D 01 05 02 24 02 03 09 06 01 00 B4 00 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 00 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B4 00 01 FF 06 00 FC 46 7E
7E A8 8C 03 00 02 00 23 EC 68 F5 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 02 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 03 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 04 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 05 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 06 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 07 FF 06 00 00 00 B0 3F 7E
7E A8 8C 03 00 02 00 23 EE 7A D6 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 08 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 01 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 02 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 03 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 5D 7C 7E
7E A8 8C 03 00 02 00 23 E0 04 3F 00 FF 02 05 09 06 01 00 B6 00 04 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 05 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 06 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 07 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FB 66 7E 7E A8 8C 03 00 02 00 23 F2 97 0C FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 08 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1E 47 FF 7E
7E A8 8C 03 00 02 00 23 E4 20 79 02 03 09 06 01 00 B4 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 0E 2E 7E
7E A0 88 03 00 02 00 23 F6 79 08 09 06 01 00 B5 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1B 2C 8A 7E
7E A0 16 00 02 00 23 03 9E 2D BE E6 E6 00 C0 02 41 00 00 00 01 04 34 7E
7E A8 8C 03 00 02 00 23 08 42 54 E6 E7 00 C4 02 41 00 00 00 00 02 00 82 03 6B 02 24 02 03 09 06 01 00 B4 00 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 00 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B4 00 01 FF 06 00 00 00 5C 1D 7E
7E A8 8C 03 00 02 00 23 0A 50 77 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 02 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 03 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 04 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 05 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 06 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 07 FF 06 00 00 00 00 02 18 3F 7E 7E A8 8C 03 00 02 00 23 0C 66 12 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 08 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 01 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 02 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 03 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF FA 8C 7E
7E A8 8C 03 00 02 00 23 1E F5 21 02 05 09 06 01 00 B6 00 04 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 05 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 06 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 07 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF 56 DA 7E
7E A8 8C 03 00 02 00 23 00 0A D8 FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 08 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 60 3B 7E
7E A8 8C 03 00 02 00 23 02 18 FB 09 06 01 00 B4 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 D0 70 7E
7E A0 86 03 00 02 00 23 14 44 4A 01 00 B5 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1B F5 00 7E
7E A0 16 00 02 00 23 03 70 5D B0 E6 E6 00 C0 02 41 00 00 00 02 9F 06 7E
7E A8 8C 03 00 02 00 23 26 3E 9C E6 E7 00 C4 02 41 00 00 00 00 03 00 82 03 6B 02 24 02 03 09 06 01 00 B4 00 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 00 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B4 00 01 FF 06 00 00 00 CA 79 7E
7E A8 8C 03 00 02 00 23 28 40 75 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 02 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 03 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 04 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 05 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 06 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 07 FF 06 00 00 00 00 02 18 3F 7E
7E A8 8C 03 00 02 00 23 3A D3 46 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 08 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 01 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 02 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 03 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF FA 8C 7E
7E A8 8C 03 00 02 00 23 2C 64 33 02 05 09 06 01 00 B6 00 04 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 05 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 06 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 07 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF 56 DA 7E
7E A8 8C 03 00 02 00 23 2E 76 10 FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 08 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 60 3B 7E
7E A8 8C 03 00 02 00 23 20 08 F9 09 06 01 00 B4 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 D0 70 7E
7E A0 86 03 00 02 00 23 32 70 0E 01 00 B5 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1B F5 00 7E
7E A0 16 00 02 00 23 03 52 4D B2 E6 E6 00 C0 02 41 00 00 00 03 16 17 7E
7E A8 8C 03 00 02 00 23 44 2A DC E6 E7 00 C4 02 41 00 00 00 00 04 00 82 03 6B 02 24 02 03 09 06 01 00 B4 00 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 00 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B4 00 01 FF 06 00 00 00 39 4E 7E 7E A8 8C 03 00 02 00 23 56 B9 EF 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 02 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 03 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 04 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 05 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 06 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 07 FF 06 00 00 00 00 02 18 3F 7E
7E A0 0A 00 02 00 23 03 91 89 42 7E
7E A8 8C 03 00 02 00 23 48 46 16 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 08 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 01 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 02 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 03 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF FA 8C 7E 7E A8 8C 03 00 02 00 23 4A 54 35 02 05 09 06 01 00 B6 00 04 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 05 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 06 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 07 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF 56 DA 7E
7E A8 8C 03 00 02 00 23 4C 62 50 FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 08 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 60 3B 7E
7E A8 8C 03 00 02 00 23 4E 70 73 09 06 01 00 B4 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 D0 70 7E 7E A0 86 03 00 02 00 23 50 64 4E 01 00 B5 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1B F5 00 7E
7E A0 16 00 02 00 23 03 34 7D B4 E6 E6 00 C0 02 41 00 00 00 04 A9 63 7E
7E A8 8C 03 00 02 00 23 72 9F 88 E6 E7 00 C4 02 41 01 00 00 00 05 00 82 03 6B 02 24 02 03 09 06 01 00 B4 00 00 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 00 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0A FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B4 00 01 FF 06 00 00 00 D6 E9 7E
7E A8 8C 03 00 02 00 23 64 28 FD 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 02 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 03 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 04 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 05 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 06 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 07 FF 06 00 00 00 00 02 18 3F 7E
7E A8 8C 03 00 02 00 23 66 3A DE 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 08 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 05 09 06 01 00 B6 00 01 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 02 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 03 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF FA 8C 7E
7E A8 8C 03 00 02 00 23 68 44 37 02 05 09 06 01 00 B6 00 04 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 05 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 06 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 07 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF 56 DA 7E
7E A8 8C 03 00 02 00 23 6A 56 14 FF FF FF FF FF 80 00 FF 02 05 09 06 01 00 B6 00 08 FF 12 00 00 02 02 0F 03 16 1B 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 02 03 09 06 01 00 B4 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 60 3B 7E 7E A8 8C 03 00 02 00 23 7C E1 61 09 06 01 00 B4 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B4 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1E 02 03 09 06 01 00 B5 00 0B FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0C FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 D0 70 7E
7E A0 86 03 00 02 00 23 7E 18 86 01 00 B5 00 0D FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0E FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 0F FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 10 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 11 FF 06 00 00 00 00 02 02 0F 03 16 1B 02 03 09 06 01 00 B5 00 12 FF 06 00 00 00 00 02 02 0F 03 16 1B F5 00 7E
7E A0 1C 00 02 00 23 03 16 3A 5F E6 E6 00 C0 01 41 00 01 00 00 85 00 02 FF 02 00 34 96 7E
7E A8 8C 03 00 02 00 23 80 02 5C E6 E7 00 C4 01 41 00 01 0A 02 07 11 03 0F 03 11 1E 11 03 03 00 11 00 11 01 02 07 11 0B 0F 03 11 20 11 01 03 00 11 00 11 03 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 B7 E1 7E
7E A0 35 03 00 02 00 23 92 43 53 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 02 07 11 FF 0F 00 11 FF 11 00 03 00 11 FF 11 FF 1B DE 7E
7E A0 1C 00 02 00 23 03 58 40 F4 E6 E6 00 C0 01 41 00 01 00 00 90 00 01 FF 02 00 CE E5 7E
7E A8 8C 03 00 02 00 23 A4 24 3B E6 E7 00 C4 01 41 00 02 03 11 00 11 04 01 0C 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 7F B4 7E
7E A8 8C 03 00 02 00 23 A6 36 18 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 4C E8 7E 7E A0 23 03 00 02 00 23 B8 1F 30 00 01 02 02 02 09 02 00 00 09 02 00 00 02 02 09 02 00 00 09 02 00 00 97 8A 7E
7E A0 0A 03 00 02 00 23 B1 64 8F 7E
7E A0 0A 00 02 00 23 03 53 97 A7 7E
7E A0 0A 03 00 02 00 23 73 7A 6A 7E
239 105265 Com COM Close
240 167500 NET
1 A 41
241 167828 NET
2 T
54 0D
6 years 1 month ago
ACE pilot is reading profile generic with logical name 0.1.98.1.0.105 and not 0.1.98.1.0.255.
Can you find 0.1.98.1.0.105 from the GXDLMSDirector?
juma
5 years 11 months ago
Dear Mikko,
Dear Mikko,
Thank you very much for your answer. I was away from work for a while, but I am returning to this topic and I have tried reading the OBIS 0.1.98.1.0.105 and you are right, there I could read 6 sets of the billing profile.
Again I thank you for your help and I will surely be asking you some more questions.
Best regards,
Juma
