  3. Wrapper Protocol
Wrapper Protocol
By deepaks , 25 May, 2020
Can i run wrapper protocol on serial port?
Thanks in advance
6 years 6 months ago
Client examples are checking that you are using TCP/IP or UDP connection. You must remove the check that the network component is used. Hen you set -w parameter and start to use WRAPPER.
