we have downloaded the latest stack and compiled successfully.
connection is success in ciphered meter. but failed to write clock object. please find the trace below
RX: 7E A0 07 03 21 93 0F 01 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 88 6D 69 F6 7E
Invocation counter: -1407940498 (0xFFFFFFFFAC14886E)
RX: 7E A0 07 03 21 53 03 C7 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 07 03 61 93 69 47 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 88 6E DB D9 86 21 4F 37 71 6B AF 49 C9 EC 97 C1 A0 F5 2F 5B EA E3 3E 80 91 98 65 24 F5 DF 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 88 6E DB D9 86 21 4F 37 71 6B AF 49 C9 EC 97 C1 A0 F5 2F 5B EA E3 3E 80 91 98 65 24 F5 DF 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 03 AA 92 16 5A 0E 2F 37 01 EE 65 48 CE EE C4 09 67 D8 B9 7F 2F 6C B8 FF 9D C3 D3 92 84 A8 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 88 6F 2C 7C C7 BE 8A 80 0D 8D 8A 2D E3 54 5D 84 E6 4E 3B 0D 30 19 B3 A6 45 57 68 34 33 85 98 13 04 6E E6 75 3A 75 12 3F F7 DA D2 C4 28 B9 65 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 88 6F 2C 7C C7 BE 8A 80 0D 8D 8A 2D E3 54 5D 84 E6 4E 3B 0D 30 19 B3 A6 45 57 68 34 33 85 98 13 04 6E E6 75 3A 75 12 3F F7 DA D2 C4 28 B9 65 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 03 AB 84 74 C9 0F CC 2B 50 63 DF CE 9D 23 DC D0 6A 10 83 77 CF BF 84 7F B2 54 EF AD FA 00 08 17 1F 58 21 9B CE FE 3B CB 7E
Writing the clock
TX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 88 71 B1 02 E9 CC F2 16 47 27 D6 95 43 8F 16 AC 37 13 C5 CD 79 30 94 63 30 8B C4 41 A4 01 8D 4B AE CF 3C 0B 21 60 BC 41 4E 5C 5A 7E
RX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 88 71 B1 02 E9 CC F2 16 47 27 D6 95 43 8F 16 AC 37 13 C5 CD 79 30 94 63 30 8B C4 41 A4 01 8D 4B AE CF 3C 0B 21 60 BC 41 4E 5C 5A 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 03 AC 71 18 05 CB 6D 0F 5B 57 B7 67 4E FC D8 7F DF 1F 0B C0 7E
Write failed Clock 00.00.01.00.00.255:2 Access Error : Device reports a inconsistent Class or Object.
Please do help us to resolve this
Mohan Raj
Hi Mohan,
Hi Mohan,
Because your data is ciphered, I can't check the bytes. You are using Push-client address, not US.
Try to change that to the correct one.
Could you please tell how to correct that address. I have tried with 0x18 which is for high level password. But failed.
Mohan Raj.
Hi Mohan,
Hi Mohan,
If you are using Indian standard meters that use IS 15959-2, US address is 48 (0x30).
This is what am passing as an argument and below is the trace. But still failed.
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.0.1.0.255:2" -v "0.0.43.1.3.255" -t "Verbose" -I
updateInvocationCounter
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 8B 02 F0 47 7E
Invocation counter: -1407939837 (0xFFFFFFFFAC148B03)
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 03 86 E5 B9 B3 6D AE 28 7A 95 BD F5 EC E2 5C 8A 2D CB 6B E7 92 C9 81 FB F5 1E B9 4E 5D 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 03 86 E5 B9 B3 6D AE 28 7A 95 BD F5 EC E2 5C 8A 2D CB 6B E7 92 C9 81 FB F5 1E B9 4E 5D 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 05 F0 10 1A E7 91 32 F9 C3 AD A2 01 BA 4C 45 98 AE 0A 54 C0 0D 40 5D B2 ED 5C 55 D5 DF A3 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 04 1E AB 2A 83 BC 5D 4B 6F 9C FF CA CD 81 52 A9 07 01 BC 24 CD 50 AB 5D 24 A1 26 C2 B1 7B 32 16 0B C4 B5 B6 44 45 CE 05 F4 F2 2E F8 09 3B 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 04 1E AB 2A 83 BC 5D 4B 6F 9C FF CA CD 81 52 A9 07 01 BC 24 CD 50 AB 5D 24 A1 26 C2 B1 7B 32 16 0B C4 B5 B6 44 45 CE 05 F4 F2 2E F8 09 3B 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 05 F1 31 F5 9D 57 1D 2E 88 ED 88 68 40 6D 76 41 AC 12 93 AB CE BE 47 43 C1 55 7F 76 C1 7C 4D E8 C1 9F AC A3 4C AE 82 83 7E
Writing the clock
TX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 8B 06 28 7E 9E DA 45 11 01 6E CE 9C 6A DD 33 6B CC 3C C2 E9 C6 36 B3 0F F3 AE 8C 8A 43 84 0F 2D C2 D8 0E 7D 3D 9D 8A EF 38 6E 76 7E
RX: 7E A0 3A 03 61 54 A7 32 E6 E6 00 C9 2C 30 AC 14 8B 06 28 7E 9E DA 45 11 01 6E CE 9C 6A DD 33 6B CC 3C C2 E9 C6 36 B3 0F F3 AE 8C 8A 43 84 0F 2D C2 D8 0E 7D 3D 9D 8A EF 38 6E 76 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 05 F2 1D 17 CD 1C 7E AD 81 EB 37 43 20 9C 45 FE 78 1A 13 4B 7E
Mohan Raj
Hi Mohan ,
Hi Mohan ,
If you connect with GXDLMSDirector can you see the clock object? What is the access level? Can you write an object?
with GXDLMSDirector am able to read clock object. But unable to write clock object. I have already created another thread for this issue when using GXDLMSDirector .Access level is ReadWrite
Mohan Raj
