  3. Unable To Read Meter
Unable to read meter
By mato3848 , 28 February, 2020
hi,
i want to connect to a meter but i cant do it,
the message from the trace are the following:
11:41:57 11:41:57.008 Info Opening
11:41:57 11:41:57.008 Info Serial Port Settings: Port Name: COM2 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Flow Control: None Eop: None
11:41:57 11:41:57.020 Info Open
11:41:58 Send SNRM request.
TX: 7E A0 1E 03 21 93 CD 3B 81 80 12 05 01 75 06 01 75 07 04 00 00 00 01 08 04 00 00 00 01 25 9C 7E
11:41:58 11:41:58.022 Sent 7E A0 1E 03 21 93 CD 3B 81 80 12 05 01 75 06 01 75 07 04 00 00 00 01 08 04 00 00 00 01 25 9C 7E
11:41:58 11:41:58.093 Received 7E A0 23
11:41:58 11:41:58.094 Received 23 21
11:41:58 11:41:58.097 Received 00 02
11:41:58 11:41:58.100 Received 00 23 73
11:41:58 11:41:58.103 Received F6 C5 81
11:41:58 11:41:58.107 Received 80 14 05 02
11:41:58 11:41:58.110 Received 00 F8 06
11:41:58 11:41:58.112 Received 02 04
11:41:58 11:41:58.116 Received B0 07 04
11:41:58 11:41:58.118 Received 00 00
11:41:58 11:41:58.120 Received 00 01
11:41:58 11:41:58.123 Received 08 04
11:41:58 11:41:58.126 Received 00 00 00
11:41:58 11:41:58.129 Received 01 D8 CC
11:42:03 Data send failed. Try to resend 1/3 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E
11:42:03 11:42:03.130 Sent 7E A0 1E 03 21 93 CD 3B 81 80 12 05 01 75 06 01 75 07 04 00 00 00 01 08 04 00 00 00 01 25 9C 7E
11:42:03 11:42:03.197 Received 7E A0
11:42:03 11:42:03.199 Received 23
11:42:03 11:42:03.202 Received 21 00
11:42:03 11:42:03.204 Received 02 00
11:42:03 11:42:03.207 Received 23 73 F6
11:42:03 11:42:03.209 Received C5 81
11:42:03 11:42:03.211 Received 80 14 05
11:42:03 11:42:03.214 Received 02 00 F8
11:42:03 11:42:03.217 Received 06 02
11:42:03 11:42:03.219 Received 04 B0
11:42:03 11:42:03.221 Received 07 04
11:42:03 11:42:03.223 Received 00 00
11:42:03 11:42:03.227 Received 00 01 08
11:42:03 11:42:03.228 Received 04 00
11:42:03 11:42:03.230 Received 00 00
11:42:03 11:42:03.233 Received 01 D8
11:42:03 11:42:03.247 Received CC
11:42:08 Failed to receive reply from the device in given time. 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E
11:42:08
RX: 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E 7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E
11:42:08 Send Disconnect request.
11:42:08 11:42:08.248 Sent 7E A0 07 03 21 53 03 C7 7E
11:42:08 11:42:08.293 Received 7E A0 0A
11:42:08 11:42:08.295 Received 0A 21
11:42:08 11:42:08.298 Received 00 02 00
11:42:08 11:42:08.300 Received 23 73
11:42:08 11:42:08.302 Received 4C E7
11:42:13 Data send failed. Try to resend 1/3 7E A0 0A 21 00 02 00 23 73 4C E7 7E
11:42:13 11:42:13.307 Sent 7E A0 07 03 21 53 03 C7 7E
11:42:13 11:42:13.338 Received 7E A0
11:42:13 11:42:13.353 Received 0A
11:42:13 11:42:13.353 Received 21 00
11:42:13 11:42:13.353 Received 02 00 23 1F
11:42:13 11:42:13.353 Received 26 4E
11:42:18 Failed to receive reply from the device in given time. 7E A0 0A 21 00 02 00 23 73 4C E7 7E 7E A0 0A 21 00 02 00 23 1F 26 4E 7E
11:42:18
RX: 7E A0 0A 21 00 02 00 23 73 4C E7 7E 7E A0 0A 21 00 02 00 23 1F 26 4E 7E
11:42:18 11:42:18.363 Info Closing
11:42:18 11:42:18.363 Info Closed
6 years 6 months ago
Try to change the server address to 16401 (0x4011) and client address to 16 (0x10).
mato3848
thanks for your reply.
i have Gurux Director 8.8.2002.1202.
i tried with Client 0x10 and server logical/physical adress 0x4011 but the Gurux Director return a popup windonw with the next error when i tried to connect: "Invalid Logical or physical Address"
When you say "server address" is the Logical o physical address?
Thanks in advance for your help and cooperation
Hi Mauricio,
Hi Mauricio,
Set Logical server to 1 and Physical server to 11.
Profile picture for user NELSON GONZALEZ
NELSON GONZALEZ
6 years 4 months ago
Hello, Itron SL7000 (Actaris
Hello, Itron SL7000 (Actaris SL7000 type SL761), after GXDLMSDirector initial configuraion and connect --> showed pop-up: " No se puede establecer una conexion ya que el equipo de destino denego expresamente dicha conexion ". Please help me to connect and read this device with GXDLMSDirector, where I can to read information for achievement it...
Your error is coming from the operating system. I believe that your TCP/IP port number is invalid and TCP/IP connection is not established.
  • 7095384824
  • koltom
  • palso
  • VigneshwaranC1993
  • Yousef Al-Saye…
