  3. Write Parameters In Meter
Write Parameters in meter
By vakilian_TFC , 13 February, 2020
I have lots of parameters that i want to set in meter with serial port in C#.
I have
Class Name.
Data.
Class ID.
Attribute ID.
OBIS.
Data Type.
how can i do this???
6 years 9 months ago
You should check client example:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
It reads all the objects from the meter. There is a write-method that you can use to write value to the meter.
