  3. Janz B280 Acess Goup D Data.
Janz B280 acess Goup D data.
By cablekiller , 5 February, 2020
I Mister Miko
I'am try to connect a Janz B280 ussing a optical probe & i have read all data except Group D, data.
I try to change the Xml in the manufacturer option but en press apply, some errors appear.
I testwith defaul Gurux XML and the errors are the same.
Funny.
I Have some of XML from Janz/Contar and i like to test them. Send latter to your email
Can you help me to gain access to Group D Obis codes?
I find VT ratio for this device is VT=210 but since new and blank devices are VT=300. Funny.
Tanks in advance & sory for my English
6 years 9 months ago
Have you tried to read the meter with GXDLMSDirector? If not, download it and select Janz as meter manufacturer and read.
cablekiller
Hi Mister Mikko
Hi Mister Mikko
Tanks for the replay.
I download Gurux Director & i install them and try it.
I Have read the meter data, association & register. But can write or modiffi any values.
I'am doing someting wrong? or Gurux Director are not corrected instalaled?
I use a Rs232 Optical prove : And i try in a Sagem CX 2000-9 whit Gurux Manufactor and same results.
I try to reinstal Gurux director but serve give me a error, ( Cannot establish a secure SSL/TTl conection, and no have Manufactors data and Gurux Director d'ont work.
I do something wrong or are some issues in Gurux server?
Sorry for the inconvenience.
Read this on Gurux Location and Version.
.NET Framework 3.5 SP 1 3.5.30729.5420 C:\Windows\Microsoft.NET\Framework\v3.5\
.NET Framework 4.0 4.6.01590 C:\Windows\Microsoft.NET\Framework\v4.0.30319\
GXDLMSDirector 8.2.2002.1202 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\GXDLMSDirector.exe
Gurux.MQTT 8.1.1910.2201 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.MQTT.dll
Gurux.Common 8.1.2001.2404 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.Common.dll
Gurux.DLMS.AMI.UI 8.1.2002.1001 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.DLMS.AMI.UI.dll
Gurux.DLMS 9.0.2002.1201 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.DLMS.dll
Gurux.DLMS.UI 9.0.2002.1202 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.DLMS.UI.dll
Gurux.Net 8.1.2002.1001 C:\Users\Lenovo\AppData\Local\Apps\2.0\6ZWKKVHB.XYC\3Q5T16WA.CZD\gxdl..tion_fac3cc4fecb816b3_0008.0002_1fc3bd69e2bbf812\Gurux.Net.dll
And this in Janz meter conection.
<?xml version="1.0" encoding="UTF-8"?>
-<Objects>
-<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
<Description>Ch. 0 Clock object #1</Description>
</GXDLMSClock>
-<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.0.255</LN>
<Description>Ch. 0 Current association</Description>
-<ApplicationContextName>
<JointIsoCtt>2</JointIsoCtt>
<Country>16</Country>
<CountryName>756</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
-<XDLMSContextInfo>
<DlmsVersionNumber>6</DlmsVersionNumber>
</XDLMSContextInfo>
-<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<SecuritySetupReference>0.0.0.0.0.0</SecuritySetupReference>
</GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<Description>Ch. 0 Association #1</Description>
<ClientSAP>16</ClientSAP>
<ServerSAP>1</ServerSAP>
<JointIsoCtt>96</JointIsoCtt>
<Country>133</Country>
<CountryName>116</CountryName>
<DlmsUA>8</DlmsUA>
-<XDLMSContextInfo>
<Conformance>4116</Conformance>
<MaxReceivePduSize>284</MaxReceivePduSize>
<MaxSendPduSize>284</MaxSendPduSize>
</XDLMSContextInfo>
<DlmsUA>8</DlmsUA>
<AssociationStatus>2</AssociationStatus>
-<GXDLMSSapAssignment>
<LN>0.0.41.0.0.255</LN>
<Description>Ch. 0 SAP Assignment</Description>
<SapAssignmentList/>
</GXDLMSSapAssignment>
-<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
<Description>Ch. 0 COSEM Logical device name</Description>
<Value Type="9">4A 43 45 42 32 38 30 20 20 20 20 20 20 20 20 20</Value>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.0.255</LN>
<Description>Ch. 0 Device ID 1, manufacturing number</Description>
<Value Type="9">31 35 31 36 30 34 38 36 32 30</Value>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.1.255</LN>
<Description>Ch. 0 Device ID #2</Description>
<Value Type="10">00 65 10 00 07 DF</Value>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.2.255</LN>
<Description>Ch. 0 Device ID #3</Description>
<Value Type="10">meterDLMS0101 </Value>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.3.255</LN>
<Description>Ch. 0 Device ID #4</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.4.255</LN>
<Description>Ch. 0 Device ID #5</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.5.255</LN>
<Description>Ch. 0 Device ID #6</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.6.255</LN>
<Description>Ch. 0 Device ID #7</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.8.255</LN>
<Description>Ch. 0 Device ID #9</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.96.1.9.255</LN>
<Description>Ch. 0 Device ID #10</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.0.0.2.0.255</LN>
<Description>Ch. 0 Active firmware identifier</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.0.0.2.8.255</LN>
<Description>Ch. 0 Active firmware signature</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.0.0.9.1.255</LN>
<Description>Ch. 0 Local time</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.0.0.9.2.255</LN>
<Description>Ch. 0 Local date</Description>
<Value Type="26">01/31/2020</Value>
</GXDLMSData>
-<GXDLMSData>
<LN>1.1.0.2.0.255</LN>
<Description>Ch. 1 Active firmware identifier</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.1.0.2.8.255</LN>
<Description>Ch. 1 Active firmware signature</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.2.0.2.0.255</LN>
<Description>Ch. 2 Active firmware identifier</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>1.2.0.2.8.255</LN>
<Description>Ch. 2 Active firmware signature</Description>
</GXDLMSData>
-<GXDLMSData>
<LN>0.0.0.94.35.31</LN>
<Description>Invalid</Description>
</GXDLMSData>
</Objects>
And comformance test
07:25:19 Send SNRM request.
07:25:19
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 1C 06 02 01 1C 07 04 00 00 00 01 08 04 00 00 00 01 C0 C4 7E
07:25:19 Send AARQ request.
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
07:25:19
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 1C 00 07 47 80 7E
07:25:19 HDLC test #1. Disconnect request
07:25:19
07:25:19 HDLC test #1. SNRM request
TX: 7E A0 20 03 21 93 7D D9 81 80 14 05 02 01 1C 06 02 01 1C 07 04 00 00 00 01 08 04 00 00 00 01 C0 C4 7E
07:25:19
07:25:19 HDLC test #1. Receiver Ready
TX: 7E A0 07 03 21 11 15 A6 7E
07:25:19
RX: 7E A0 07 21 03 11 15 00 7E
07:25:19
07:25:19
RX: 7E A0 07 21 03 1F 6B E9 7E
07:25:19 HDLC test #2. SNRM request
07:25:24
07:25:25
07:25:25 HDLC test #2. Illegal frame.
07:25:30
07:25:35
Tanks an sorry for the troubles
Dino
Hi Dino,
Hi Dino,
If you want to write values to the meter you need to change the authentication level and client address.
Without the authentication you can only read.
You have tried to run DLMS conformance tests for the meter and it seems meter didn't pass those tests.
