  3. Can't Get Few Parameters
Can't get few parameters
By DemoniKsataNa , 11 November, 2019
I tried get data from 4 registers of meter SL7000 by using GuruxDirector. I got this log:
GXDLMSDirector 8.2.1910.3102
Log created 8:25:39
08:27:28 Initializing serial connection.
8:27:29 Send SNRM request.
7E A0 21 00 22 00 51 03 93 6B 21 81 80 12 05 01 80 06 01 80 07 04 00 00 00 02 08 04 00 00 00 01 3D 93 7E
8:27:30
7E A0 23 03 00 22 00 51 73 E7 04 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
08:27:30 Parsing UA reply succeeded.
8:27:30 Send AARQ request.
7E A0 47 00 22 00 51 03 10 B0 6B E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 19 02 7E
8:27:30
7E A0 53 03 00 22 00 51 30 34 65 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 01 AA 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 21 34 00 07 9A C7 7E
08:27:30 Parsing AARE reply succeeded.
8:27:33 Read object type Register index: 2
7E A0 1C 00 22 00 51 03 32 ED 6D E6 E6 00 C0 01 C1 00 03 01 01 01 08 00 FF 02 00 E7 F7 7E
8:27:33
7E A0 18 03 00 22 00 51 52 A4 94 E6 E7 00 C4 01 C1 00 06 04 B0 2B E4 62 86 7E
8:27:40 Read object type Register index: 2
7E A0 1C 00 22 00 51 03 54 DD 6B E6 E6 00 C0 01 C1 00 03 01 01 02 08 00 FF 02 00 9A FB 7E
8:27:40
7E A0 18 03 00 22 00 51 74 90 D0 E6 E7 00 C4 01 C1 00 06 00 00 02 4C A5 A3 7E
8:27:46 Read object type Register index: 2
7E A0 1C 00 22 00 51 03 76 CD 69 E6 E6 00 C0 01 C1 00 03 01 01 03 08 00 FF 02 00 B1 FF 7E
8:27:46
7E A0 18 03 00 22 00 51 96 8C 14 E6 E7 00 C4 01 C1 00 06 01 4C 86 D0 82 A9 7E
8:27:51 Read object type Register index: 2
7E A0 1C 00 22 00 51 03 98 BD 67 E6 E6 00 C0 01 C1 00 03 01 01 04 08 00 FF 02 00 60 E3 7E
8:27:51
7E A0 18 03 00 22 00 51 B8 F0 DC E6 E7 00 C4 01 C1 00 06 00 00 00 13 67 3A 7E
08:27:58 Disconnect request
7E A0 0A 00 22 00 51 03 53 66 F2 7E
8:27:58
7E A0 0A 03 00 22 00 51 73 5D 26 7E
Then, i tried use this commands in my C# programm, but i got this log(picture):
What's problem? Did I miss something?
Maybe some delays?
DemoniKsataNa
6 years 8 months ago
I found mistake. frame type
I found mistake. frame type of GET request is different in every frame.
Frame ID is increased for each time you send data or meter reply. It's correct.
Please, don't send images. It's hard check the bytes.
DemoniKsataNa
That means, i can only send 7
That means, i can only send 7 get requests?
I mean: 0x32, 0x54, 0x76, 0x98, 0xBA, 0xDC, 0xFE. And then i have to send snrm and AARQ requests again? Weird technology...
No, frame sequence number starts again from zero. Please, use open source libraries. You are spending time. If HDLC framing is causing now problems, wait until data is coming in fragments.
  • XeOnQbGXMRpiRxdHdAt
  • Michaeldob
  • Jerrytar
  • Walterspize
  • WilliamGeoxy
