  3. Download XML Schema
Download XML Schema
By hugoabreu1002 , 31 October, 2019
Hello, I am facing a problem in my project.
I already have made some questions, but this time I'll explain better.
We are developing a new meter. For this development we need to create a test plan, that's why we are using Gurux.
Problema is. For this new meter I'm afraid it will not be possible to generate a .gxc with the steps in (https://www.gurux.fi/GXDLMSDirector.Manufacturers), reason is, that a prototype will not be ready in time and the name and ID will not be available at (http://www.dlms.com/organization/flagmanufacturesids/index.html).
So, the final option is to general the .gxc using a XML schema for all possible objects.
Finally, my question is. Do you have an XML Schema avaible for all your objects ? There's a way one can build your own XML Schema?
7 years ago
It's not possible to generate XML schema for all possible objects because amount of the OBIS codes is so huge. Meter MUST return supported COSEM objects in association view.
If the association view is empty, you can add objects by hand in develop time selecting
"Add object..." from "Edit" menu.
You must select object type and set logical name for the object and then accept the new object.
