  3. Scalar Application Issue In Event Data
Scalar Application issue in event data
By Balveer Singh , 2 May, 2019
Here is the traffic log of a tamper profile -
Response
7E A0 8A 41 03 96 0E 53 E6 E7 00 C4 02 81 01 00 00 00 01 00 82 00 72 01 02 02 0D
09 0C 07 E3 05 02 FF 0B 0F 00 00 01 4A 00 - RTC
12 00 C9 - ID
12 07 D0 - R-Current
12 07 D0 - Y-Current
12 07 D0 -B-Current
12 5D C0 -R-Voltage
12 5D C0 -Y-Voltage
12 5D C0 -B-Voltage
12 00 64 -R-PF
12 00 64 -Y-PF
12 00 64 -B-PF
06 00 03 BF C4
06 00 03 C2 08
Now the scalar is :
12:05:47 Read object type ProfileGeneric index: 4
TX: 7E A0 19 03 41 FE 5A B1 E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 04 00 60 41 7E
12:05:47
RX: 7E A0 15 41 03 1E 78 07 E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
12:05:47 Reading profile generic data 1.0.94.91.7.255
TX: 7E A0 19 03 41 10 2A BF E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 02 00 B0 15 7E
12:05:47
RX: 7E A0 5E 41 03 30 A6 19 E6 E7 00 C4 02 81 01 00 00 00 01 00 82 00 46 01 01 02 0B 02 02 0F FF 16 21 02 02 0F FF 16 21 02 02 0F FF 16 21 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FE 16 23 02 02 0F FE 16 FF 02 02 0F FE 16 FF 02 02 0F FE 16 FF 02 02 0F 00 16 1E 02 02 0F 00 16 1F 38 CF 7E
12:05:47 Read object type ProfileGeneric index: 5
TX: 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 05 00 B8 58 7E
12:05:47
RX: 7E A0 12 41 03 52 31 D8 E6 E7 00 C4 01 C1 00 16 01 9A 11 7E
12:05:47 Read object type ProfileGeneric index: 6
TX: 7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 06 00 D0 72 7E
12:05:47
RX: 7E A0 22 41 03 74 F7 D0 E6 E7 00 C4 01 C1 00 02 04 12 00 00 09 06 00 00 00 00 00 00 0F 00 12 00 00 7C 19 7E
12:05:47 Read object type ProfileGeneric index: 7
TX: 7E A0 19 03 41 76 1A B9 E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 07 00 08 6B 7E
12:05:47
RX: 7E A0 15 41 03 96 38 0F E6 E7 00 C4 01 C1 00 06 00 00 00 01 F4 09 7E
12:05:47 Read object type ProfileGeneric index: 8
TX: 7E A0 19 03 41 98 6A B7 E6 E6 00 C0 01 C1 00 07 01 00 5E 5B 07 FF 08 00 C0 E8 7E
12:05:47
RX: 7E A0 15 41 03 B8 44 C7 E6 E7 00 C4 01 C1 00 06 00 00 00 01 F4 09 7E
as shown in Gurux- application
{0.1, Current} {0.1, Current} {0.1, Current} {0.01, Voltage} {0.01, Voltage} {0.01, Voltage} {0.01, NoUnit} {0.01, NoUnit} {0.01, NoUnit} {1, ActiveEnergy} {1, ApparentEnergy}
And the Values are :
05/02/2019 11:15:00.000
201
20 20 20 240 240 240 0.1 0.1 0.1 245700 246280
In above values, values of Current is 20 instead of 200 and power factor is 0.1 instead of 1(no unit)
-- No issue with voltage values
For example
from Traffic
12 07 D0 - R-Current is 2000 and downloaded value is 20 while scalar is 0.1, while it should be 200, same applies to POWER FACTOR.
7 years 6 months ago
Dear Balveer Singh,
Dear Balveer Singh,
If scaler is read before reading the value, the scaler is used to multiply the read value.
Balveer Singh
I have tried with downloading
I have tried with downloading the values before or after downloading the scalar, values doesn't change, even if i do not download the scalar, the values remain same, correct scalar is applied in voltage but incorrect with Current and PF
Can you read current scaler and unit and post trace here? I'll check what meter returns.
Balveer Singh
Hello Sir,
Hello Sir,
Here is the response of the scalar what I'm getting from the meter
Command :
Response :
Here the current scalar is:
02 02
0F FF 16 21
02 02
0F FF 16 21
02 02
0F FF 16 21
and i get Data values as response are as :
12 07 D0 - B-Current
Hello Sir,
Hello Sir,
OK. You are using the Indian standard. IS 15959-2 and your meter don't support direct scaler request from the register. Your meter is using profile generic table to save scalers.
GXDLMSDirector doesn't support this at the moment. You need to update scalers by your self. I add this to the work list and we'll add support for Profile Generic scaler table on the future releases.
