  3. GXDLMSObject 'invalid' Description
GXDLMSObject 'invalid' description
By dvillanueva , 10 January, 2019
Gurux DLMS for Android
Hi!
I want to read the description of all my GXDLMSObjectCollection objects. I call the function
"(GXDLMSObjectCollection).save(final OutputStream stream, final GXXmlWriterSettings settings)"
and creates the XML correctly but the function (GXDLMSObject).getDescription always return the String "Invalid" in ALL objects. Please, can you help me?
Best regards.
arun
4 years 9 months ago
I am also facing same issue ,
I am also facing same issue , I am reading the DLMS meter and in retrun XML I find "Invalid" in description
See below :
<Objects>
<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
<Description>Invalid</Description>
<Access>111111111</Access>
<MethodAccess>000000</MethodAccess>
<Time>03/05/2022 15:18:43-05:30</Time>
<TimeZone>330</TimeZone>
<Status>0</Status>
<Begin>03/05/2022 15:18:43-05:30</Begin>
<End>03/05/2022 15:18:43-05:30</End>
<Deviation>0</Deviation>
<Enabled>0</Enabled>
<ClockBase>1</ClockBase>
</GXDLMSClock>
<GXDLMSIecHdlcSetup>
<LN>0.0.22.0.0.255</LN>
<MethodAccess />
<Speed>5</Speed>
<WindowSizeTx>1</WindowSizeTx>
<WindowSizeRx>1</WindowSizeRx>
<MaximumInfoLengthTx>128</MaximumInfoLengthTx>
<MaximumInfoLengthRx>128</MaximumInfoLengthRx>
<InterCharachterTimeout>1000</InterCharachterTimeout>
<InactivityTimeout>40</InactivityTimeout>
<DeviceAddress>256</DeviceAddress>
</GXDLMSIecHdlcSetup>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<Access>11111101</Access>
<MethodAccess>0000</MethodAccess>
<ObjectList>
<GXDLMSClock>
</GXDLMSClock>
<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
<Access>11</Access>
</GXDLMSData>
<GXDLMSData>
<LN>0.0.96.1.0.255</LN>
<Access>11</Access>
</GXDLMSData>
</ObjectList>
<ClientSAP>16</ClientSAP>
<ServerSAP>1</ServerSAP>
<ApplicationContextName>
<JointIsoCtt>2</JointIsoCtt>
<Country>16</Country>
<CountryName>756</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<Conformance>524288</Conformance>
<MaxReceivePduSize>200</MaxReceivePduSize>
<MaxSendPduSize>500</MaxSendPduSize>
<DlmsVersionNumber>6</DlmsVersionNumber>
<QualityOfService>0</QualityOfService>
<CypheringInfo />
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<MechanismId>0</MechanismId>
<Secret />
<AssociationStatus>2</AssociationStatus>
<SecuritySetupReference>0.0.0.0.0.0</SecuritySetupReference>
<Users />
<MultipleAssociationViews>0</MultipleAssociationViews>
</GXDLMSAssociationLogicalName>
<GXDLMSData>
<Access>11</Access>
<MethodAccess />
<Value Type="9">48 50 4C 50 50 45 4D 36 58 58 58 30 31 20 20 20</Value>
</GXDLMSData>
<GXDLMSData>
<Access>11</Access>
<MethodAccess />
<Value Type="9">48 30 30 30 30 30 30 30</Value>
</GXDLMSData>
</Objects>
4 years 8 months ago
What version you are using? Have you modified the source code? This is now tested and it works without problems with several different Android versions and different meters.
Are you reading the association view from the meter or are you adding COSEM objects by yourself?
Profile picture for user Mervat Elalem
Mervat Elalem
1 year 9 months ago
I am also facing same issue,…
I am also facing same issue, I am reading the DLMS Water meter and in Gurux I find "Invalid" in description .
For registers:
8.0.1.0.0.255
8.0.1.0.1.255
8.0.1.0.2.255
8.0.1.0.3.255
