  3. Monitoring
Monitoring
By vinayak , 19 November, 2018
Can we use same code for monitoring multiple parameters of multiple dlms meters. How Gurux directory supports in this.
7 years 8 months ago
Monitoring
I'm sorry. Do you mean OBIS code (Logical name)?
The general idea in DLMS is that all the meters should use the same OBIS codes.
In this way, you can query the same data from different meters.
vinayak
In reply to Monitoring by Kurumi
Monitoring
Hi Sir,
Thanks for your reply.
We are reading multiple parameters from a meter and it shows error after few cycles of reading data.
We are requesting parameters one by one .
7 years 5 months ago
Monitorin
Check what is inactivity timeout. It might that keepalive is not send and meter closes connection if nothing is read for a while.
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
  • highclassrightway
  • sapran
