  3. EM101+ Technical Support
EM101+ Technical support
By Srinivas_Srini , 10 November, 2018
Gurux.Serial
Hello Team.
I need to extract data ( Voltage, Current etc) from EM101+ Energy meter. To extract data am using Guru GXDLMSDIRECTOR. But in that explorer can't able to find L & T device in manufactures list.
Kindly advise and help to extract the data for further process.
Regards
Srini
7 years 8 months ago
Hi Srini,
EM101+ is not supporting DLMS. It's using IEC1107. You can't read it with DLMS.
h24h
7 years 7 months ago
setup APN
i can add the APN , Gateway and Subnetmask
but when i try to add the IP (which is a real IP) it is disappeared after trying to save
setup APN
I believe that meter is not returning any errors. Can you try to write it and send log to me.
h24h
setup APN
i sent the log file via the email
setup APN
Check the data. Data is correct and meter reply Success, but for some reason, the meter doesn't update IP address. I believe that your SIM is using dynamic IP address and you can't set static IP address.
You should check that.
h24h
setup APN
i double checked the SIM and assured it use StaticIP , The problem that the meter look like it didnot save the IP . , i almost tried every thing and i can access the mobile , read all data , but i don't know why it is not saving the IP
setup APN
I just realize what is the problem. You are using static IP address and it's given from the APN.
You can't change it.
h24h
setup APN
i don't know if i understand you right , My SIM already has a static IP
what i want to do is to write that IP on the meter to connect to it
otherwise what IP i will use to connect to the meter
Hope you can kindly clarify or just tl me what to write to the meter if for Ex. the static IP of the sim is 82.129.132.26
Really appreciate your great response and support
7 years 6 months ago
setup APN
Have you read this?
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
