  2. Manufacture Specific Object Types For Gurux DLMS/COSEM Class
By Administrator , 10 June, 2014
Getting started
Sometimes device manufacturers are using custom objects to add new functionality to the meters although this is not recommended.
You can create Manufacture specific object types (IC) for Gurux DLMS/COSEM in the following way.
1. Add a custom ID to the object type enum. C# uses an event notifier that can create a wanted object.
  • Java
  • C#
  • Delphi
  • ANSI C++
GURUX_CUSTOM_OBJECT(1234),
OBJECT_TYPE_GURUX_CUSTOM_OBJECT = 1234
2. Make your own class ex. GuruxCustomObject and derive it from GXDLMSObject and IGXDLMSBase. Then add constructor where you tell class ID.
  • Java
  • C#
  • Delphi
  • ANSI C++
         * Gurux manufacture the specific object.
        class GuruxCustomObject extends GXDLMSObject implements IGXDLMSBase
             * Constructor.
            public GuruxCustomObject()
                super(ObjectType.GURUX_CUSTOM_OBJECT);
             * Returns collection of attributes to read.
             * If attribute is static and already read or device is returned HW error it is not returned.
            int[] getAttributeIndexToRead()
            * Returns amount of attributes.
            int getAttributeCount()
             * Returns amount of methods.
            int getMethodCount()
             * Returns collection of class values.
            @Override
            public Object[] getValues()
                return new Object[] {getLogicalName(), };
            * Returns value of given attribute.
            Object getValue(int index, int selector, Object parameters)
            * Set value of given attribute.
           void setValue(int index, Object value)
            * Invokes method.
             @param index Method index.
           byte[][] invoke(Object sender, int index, Object parameters)
        /// Gurux manufacture spesific object.
        public class GuruxCustomObject : GXDLMSObject, IGXDLMSBase
            /// Constructor.
                : base(ObjectType.GuruxCustomObject)
            #region IGXDLMSBase Members
            /// Returns collection of attributes to read.
            /// If attribute is static and already read or device is returned HW error it is not returned.
            /// Collection of attributes to read.
            public int[] GetAttributeIndexToRead()
            /// Returns amount of attributes.
            /// Count of attributes.
            public int GetAttributeCount()
                throw new NotImplementedException();
            /// Returns amount of methods.
            public int GetMethodCount()
            /// Returns names of attribute indexes.
            public string[] GetNames()
            /// Returns attributes as an array.
            /// Collection of COSEM object values.
            public override object[] GetValues()
            /// Returns value of given attribute.
            /// When raw parameter us not used example register multiplies value by scalar.
            /// Attribute index
            /// Value of the attribute index.
            public object GetValue(int index, int selector, object parameters)
            /// Set value of given attribute.
            /// Attribute index
            public void SetValue(int index, Object value)
            /// Invokes method.
            /// Method index.
            public byte[][] Invoke(object sender, int index, object parameters)
            #endregion
//Gurux manufacture spesific object.
        class CGuruxCustomObject : public CGXDLMSObject
            //Constructor.
            GuruxCustomObject() : CGXDLMSObject(OBJECT_TYPE_GURUX_CUSTOM_OBJECT)
        	//Get attribute values of object.
        	void GetValues(vector<string>;& values)
            virtual int GetValue(int index, int selector, CGXDLMSVariant;& parameters, CGXDLMSVariant;& value)
            virtual int SetValue(int index, CGXDLMSVariant;& value)
            // Invokes method.
            virtual int Invoke(int index, CGXDLMSVariant;& parameters)
        	void GetAttributeIndexToRead(vector<int>& attributes)
After you have created your class you must add it to the class factory. In C# this is done by listening OnCustomObject event.
  • Java
  • C#
  • Delphi
  • ANSI C++
        //createObject is located to GXDLMS.java
        static GXDLMSObject createObject(ObjectType type)
            if (type == ObjectType.GURUX_CUSTOM_OBJECT)
                return new GuruxCustomObject();
//Create manufacturer-specific custom COSEM object.
client.OnCustomObject += (type, version) =>
   if (type == 6001)
   return null;
        CGXDLMSObject* CGXDLMSObjectFactory::CreateObject(OBJECT_TYPE type)
            if (type == OBJECT_TYPE_GURUX_CUSTOM_OBJECT)
                return new CGuruxCustomObject();
Now your custom IC is ready. Next time when you are reading your Association View your new IC is shown as well.
