Return exception if AARQ fails because ciphered data is invalid.
Project:
gurux.dlms.cpp
Wrong Authentication key, or block cipher key can cause that ciphered data is invalid.
At the moment server is not return anything if ciphered data is invalid.
Return Permanent rejected, No reason Given exception if parsing AARQ fails.
This will help handling ciphered data.
Status:
Closed (fixed)
Priority:
Normal
Category:
Feature request
Component:
Code
Reporter:
Administrator
Created:
Tue, 09/26/2017 - 12:21
Updated:
Tue, 09/26/2017 - 16:00
Comments
Administrator's picture
Status: Active » Closed (fixed)
