  3. FTDI Configuration On Gurux.Serial.Android-master
FTDI configuration on Gurux.Serial.Android-master
By Jaume Sole , 29 June, 2017
Gurux.Serial
I've been testing in order to verify that my probe functions correctly the demo app you have developed.
I've noticed minor changes should be done:
- in file device_filter.xml
<usb-device vendor-id="1027" product-id="24557" class="255" subclass="255" protocol="255" />
product-id should be #6001 -> 24577 (not 24557)
all probes I've tested have subclass and protocol both 255
- in GXFtdi.java
in function is using should be:
if ((vendor == 1027 && product == 24577) || "FTDI".equalsIgnoreCase(stringManufacturer)) {
vendor is repeated and number is not correct
- consider adding to the androidmanifest.xml
<uses-feature android:name="android.hardware.usb.host" />
With those minor changes I've been able to send using this demo.
THanks
9 years ago
Our client is using cheap Chinese USB dongle with this product-id.
We added your product id.
We modified app's androidmanifest.xml. Not it contains.
<uses-feature
android:required="true" />
This was already included to component's androidmanifest.xml.
New version is released:1.0.8.
Thanks from your feedback. I added your name to credits.
  • Rolling-Slots-Bok
  • OskoNadyLoold
  • @Hmd- several '.
  • Dawsontot
  • Jerrylam
