  3. Season Profile
Season Profile
Profile picture for user ivan
By ivan , 12 May, 2017
I've cloned latest code from github, and I found some errors during build.
I've compared with my older code, and I saw that GXDLMSSeasonProfile.cs is changed to expect and returns byte[] instead string.
I Know that it was intention because of following comment
"Some manufacturers are using non ASCII names."
But this produce errors in following files
GXDLMSSFSKActiveInitiatorView.cs
GXDLMSActivityCalendarView.cs
I'm using only following projects
Gurux.Common
Gurux.DLMS.UI.Net
Gurux.Net
GXDLMSDirector
When it was string as argument and as return type it was fine.
So what is your intention to do?
small error:
GXDLMSAssociationLogicalNameView.cs
error Line 134
MaxSendPDUSizeTb.Text = target.XDLMSContextInfo.MaxSendPpuSize.ToString();
Should change to MaxSendPDUSizeTb.Text = target.XDLMSContextInfo.MaxSendPduSize.ToString();
Kind regards,
Ivan
9 years 6 months ago
Season Profile
Hi Ivan,
We have made a lots of changes for DLMS.UI. New version is available.
We have also fixed this typo.
ivan
Fixed (almost)
Thank you for your fast fix.
It lefts one more small bug in Gurux.DLMS.UI.Net solution, when you open it in Visual studio (I'm using 2017) GXDLMSMBusMasterPortSetupView.cs resource GXDLMSMBusMasterPortSetupView.resx is excluded by default.
Kind regards,
Ivan
Season Profile
Hi Ivan,
This is fixed.
