I am trying to use the latest version of Gurux.DLMS.cpp on windows but I am confused how to set the authentication.
I initiate the meter as below:
CGXDLMSClient cl(true, 3, serverAddress, GXDLMS_AUTHENTICATION_LOW, "ABCDEFGH");
It, however, sends "34 E6 30 00 00 00 00 00" to the meter as the password and then I get:
AARQRequest failed 21.
InitializeConnection failed Authentication mechanism name not recognised..
I would be pleased if you help me know how to initiate with authentication.
Thank you for your new version. I already tested it. It worked well on windows but in ubuntu OS it sends "2F 65 74 63 2F 6C 6F 63" as the password.
My setting is:
CGXDLMSClient cl(true, 3, serverAddress, GXDLMS_AUTHENTICATION_LOW, "ABCDEFGH", GXDLMS_INTERFACETYPE_HDLC);
Set AUTHENTICATION in Gurux.DLMS.cpp (new API)
We have updated new version to GitHub where we have fixed this.
Thank you for reporting this.
My setting is:
Thank you again.
Best regards,
Leila
Did you get latest version from GitHub and remember build it?
I verify this and it works on my Linux.
Thank you for you time. I got the new version and then the problem didn't show again.
Best Regards,
Leila
