  2. How To Create a Good Issue
Issue
Question is not an Issue
If you have a question do not create an issue from that. We are answering questions on Forum.
If your meter is not answering, it's not an issue, it's a question. There are several meter settings that might cause it.
How to create a good issue
This page details the process for creating a well-crafted issue report. This will help you get progress faster, because it makes it easier for others to help you!
Before you open an issue
Try first to search the issue queue first. Make also sure that you have selected the right program version.
Title
Your title should be descriptive and concise. Explain the error shortly.
Project
In most cases Project will be automatically populated. Make sure this is correct. Do not try to add ANSI C issues to Delphi, etc.
Version
When reporting a bug, be sure to specify the version where you found the bug. To best help the developers, upgrade to the latest official release and verify the bug still exists.
Component
Select is the issue on code, documentation, or user interface.
Category
A category determines the broad grouping under which your issue falls. Defining the category for an issue.
Priority
Priority is used to define the relative importance of your issue to the project and other issues in the queue. It does not define the importance of the issue to you personally.
  • Critical is used to designate broken functionality that makes the project unusable (e.g. data loss, data corruption). "Critical" should be reserved for the most problematic and important issues. Abuse of the Critical field will likely get your issue ignored by a developer.
  • Major is used for issues that have significant repercussions but do not render the whole system unusable.
  • Normal is the default priority applied.
  • Minor is when there is no urgency to solve the issue.
Status
Each issue has a status assigned so that we can tell at a glance what progress has been made with each issue. Do not change this!
Description
The Description field is wide open which leaves you a lot of space to say a lot or a little.
If you have an issue with your meter, it is always good if you can attach a log file. In GXDLMSDirector you can get a hex log file by selecting "View Log" under "Tools" menu.
