By ivansugi, 26 March, 2014
Hi Gurux,
i have connect using data call (terminal connection) with default actaris setting, and below is the log file.
9:58:29 AM Initializing Terminal connection.
9:58:55 AM Send SNRM request.
7E A0 0A 00 00 00 23 21 93 90 67 7E
9:59:00 AM Failed to receive reply from the device in given time.
My meter version is actaris SL7000, the actaris guys tells me that the version is SL761, I've managed to get some data with the ClientID = 0x01 and ServerID = 0x11 both in Byte, can you tell me the default serverID and clientID for that Actaris Settings.
cause on Gurux.DLMS.GXDLMSServerBase.CountServerID it is an abstract class.
But the reply from the meter is either stuck in this "while (!_parser.IsDLMSPacketComplete(p.Reply))" or raise a "Not UA Response" exception.
cause no way I can get the serial connection, since actaris guys never give me the correct serial cable.
My initial hipothesis for this is because the GSM problem, have you encounter the similar problems?
Actaris SL 7000
First I have to ask what is your meter version?
You can read more here:
http://www.gurux.fi/node/201
SL7000
thanks
i found the problem actually
i found the problem actually a modem connection.
SL7000
Great if you solved the problem. Usually with our DLMS/COSEM products everything is working well and if there are any problems they are:
1. Parameters are wrong.
2. There is some problems with connection to the meter.
yes thanks kurumi :)
