By ivansugi, 6 January, 2014
I'm new to COSEM and Gurux, I have a modem which i can send sms with gammu, but when i tried to connect to meter (the meter si actaris SL7000), it says no carrier error. I tried to send sms with terminal type
"No carrier" error means that your modem can not make connection to the meter.
You said that you are can send SMSs so I believe that you are using GSM network.
Am I right?
I want to establish a connection between my pc to actaris meter. I have done it with your lib via serial port. but when i put two of my gsm modem (maestro 100 (on actaris meter) & wavecom (on my pc)). It didn't connect (the no carrier error) do I have to add another features on my simcard (such as, fax features) or can I use PDU mode sms?
I actually don't know which method use to get data from actaris meter. my lecturer says that I must use PDU mode (which is failed to get response, but PDU code is sent), but you said it must be done with Byte mode (as in fax)..
Sorry, I have missed your post and just find it. We received A LOT of spam and that caused some problems. :-(
Those problems are now fixed and everything should be working now. :-)
You can't use SMS. Are you receiving any feedback from the modem?
cannot send SMS
Am I right?
yes, i'm using GSM Network,
yes, i'm using GSM Network, is it must be ATD command or just AT command?
cannot send SMS
Do you want to send SMS or make a call?
establish connection
which one is correct actually?
thanks
