By martin_gurux, 1 July, 2013 I am trying zu read an Iskra MT851 with Director Version 7.0.12.1 and an USB based optical device. This is what I get: bei GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:Zeile 964. 09:21:07 Initializing serial connection. 09:21:07 HDLC sending:/?! 09:21:08 HDLC received: /ISK3\@01MT851-0047 09:21:08 BaudRate is : 2400 09:21:08 Moving to mode E. 06 32 33 32 0D 0A 09:21:08 Disconnect request 09:21:08 Failed to receive reply from the device in given time. System.Exception: Failed to receive reply from the device in given time. bei GXDLMSDirector.GXDLMSDevice.InitializeConnection() in C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:Zeile 345. bei GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:Zeile 964. 09:21:53 Initializing serial connection. 09:21:53 Send SNRM request. 7E A0 08 02 23 C9 93 E4 43 7E Data send failed. Try to resend 1/3 Data send failed. Try to resend 2/3 09:22:08 Failed to receive reply from the device in given time. 3F 3F 00 3F 1A 3F 3F 7B 3F 7B 7F 3F 3F 39 7D 79 3F 3F 3F 37 3F 79 33 30 30 29 0D 0A 31 2E 38 2E 31 2A 39 36 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 31 30 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 39 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 38 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 37 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 36 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 3F 3F 7F 3F 3F 5F 76 7A 7A 37 3F 3F 6E 3F 3F 72 36 3F 3F 3F 3F 18 3F 3F 18 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 34 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 33 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 32 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 31 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 30 30 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 39 39 28 30 30 30 30 30 30 30 29 0D 0A 31 2E 38 2E 32 2A 39 38 28 30 30 30 30 30 30 36 3F 3F 5F 3F 7E 3F 7E 5B 3F 3F 5F 36 2D 3F 3F 3A 3F 43 02 02 02 02 02 02 02 3F 3F 4A 3F 3F 3F 3F 6B 3F 3F 26 7C 31 2E 38 2E 32 2A 39 36 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 2A 31 30 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 2A 30 39 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 2A 30 38 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 2A 30 37 28 30 30 30 30 30 30 30 29 0D 0A 33 2E 38 2E 30 2A 30 36 28 30 30 30 30 30 30 30 29 0D System.Exception: Failed to receive reply from the device in given time. bei GXDLMSDirector.GXDLMSDevice.InitializeConnection() in C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:Zeile 345. bei GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:Zeile 964. Similar erros appear when I try to read other Iskra Meters. Any idea ? Regards Martin Can't read Iskra MT851 Hi Marint, It seems that we move little bit too fast to mode E with Iskra meters. This problem is happening randomly. We have fixed this by increasing sleep delay. We will release new version in next week from GXDLMSDirector. I hope that this will help you. Can't read Iskra MT851 Hi, I'm just curious. Do you still have this problem? BR, Mikko Log in or register to post comments
Hi Marint,
