By tremors80, 13 November, 2012
I'm using TCP/IP connection with meter and I have one problem. On my Pc I have two different ethernet devices: one for the internet and one for the meter.
Can I choose the ethernet device in parameter configuration? How can modified the code to select the correct ethernet device?
Your question is very good. We have to think something for this.
You can modify the source code. You will instructions how to get the source code from here: http://www.gurux.fi/OpenSource
If you made a solution for this we really appriciate if you contribution changes for the community.
GxNet configuration
You can fix IP with ethernet
You can fix IP with ethernet connection. Or you can list network connection in your computer with code:
http://stackoverflow.com/questions/2576858/how-to-get-network-connectio…
http://social.msdn.microsoft.com/Forums/en-US/csharpgeneral/thread/2be9…
