i´m getting the following error: what is the problem ?
at GXDLMSDirector.GXDLMSBase.ReadProperties(Boolean InitialValues, GXDLMSCommunicator comm, PropertyDescriptorCollection properties, Object target) in C:\Projects\GXDLMSDirector\Development\GXDLMSBase.cs:line 445
at GXDLMSDirector.GXDLMSBase.ReadProperties(Boolean InitialValues, GXDLMSCommunicator comm, PropertyDescriptorCollection properties, Object target) in C:\Projects\GXDLMSDirector\Development\GXDLMSBase.cs:line 413
at GXDLMSDirector.GXDLMSBase.Read(Boolean InitialValues, GXDLMSCommunicator comm, Int32 attribute) in C:\Projects\GXDLMSDirector\Development\GXDLMSBase.cs:line 465
at GXDLMSDirector.MainForm.ReadMnu_Click(Object sender, EventArgs e) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 863
If you have just read some values from the meter and it fails it might be that sometimes meter do not response if it doing something important or
packet is actually lost.
If you have do not read anything for a while and read fails KeepAlive time is too long (Default 40 s). Some manufacturers are using smaller KeepAlive time.
Make it smaller. Select Manufacturers from Tools menu to do this.
Communicating with Janz C280
Can you tell Manufacturer of this meter. This is new meter for us.
Thanks for your help, the Manufacturer of this meter is Janz S.A, it´s a Portuguese Manufacturer they make meters since 1915
They have 2 DLMS Manufacturer ids : JCE and JGF
The Serial port of this meter follow thw standard IEC62056-21 - Protocol FLAG - Mode E ,and have a integred GSM modem working at 9600baud
http://www.janzce.pt/index.php?section=2
Regards
Mario
Hi kurumi,
I already find the correct config to connect to Janz C280 meter:
is the Following:
Manufacturer Name: Janz SA.
Manufacturer ID: JCE
Check the option "use logical name referencing"
inativity Mode: KeepAlive
Keepalive interval : 40
Start Protocol: DLMS
Authentication : none
Client Adress(hex):10 type: byte
Server Adress:
Address Type: Default
Type: Byte
Serial Number Formula:
Physical: 1 Logical :0
Version used to connect : DLMS/COSEM Director 1.0.0.235 Media: terminal
if you need the obis codes for Janz , please tell how i can extract them.
Regards
Mario
Janz C280
Hi Mario,
Thank you very much for your help.
We have published Janz template so now it is easy to use from Gurux products.
Error when connecting C280
thanks for your Help
Mario
