By Dlmstudent, 9 April, 2012
Hello I'm trying to connect Actaris SL700 meter using serial port and optical port but i can´t connect the meter. The view log show this
13:17:59 Initializing serial connection.
13:18:01 Send SNRM request.
7E A0 0A 00 00 00 03 21 93 AB 64 7E
13:18:20 Failed to receive reply from the device in given time.
13:25:14 Initializing serial connection.
13:25:14 Send SNRM request.
13:25:32 Failed to receive reply from the device in given time.
13:25:49 Initializing serial connection.
13:25:49 Send SNRM request.
13:26:07 Failed to receive reply from the device in given time.
I check and the physical connection is well, the optical probe is good, i don't know what is the problem.
Please helph me and sorry for my english, I am Latin American :)
Hello, in the first post,i had in the device properties how start protocol DLMS, know i configure how start protocol IEC and i get the following view log:
and dialog box say: "Manufacturer type does not match. Manufacturer is SLB and it should be ACE" please explain to me what this means? many thanks for your help
Connect Actaris SL700
14:35:36 Initializing serial connection.
14:35:36 HDLC sending:/?!
14:35:37 HDLC received: /SLB5\2SLB_AMBER_000001
You should select Atraris to the manufacturer.
See default settings from here:
