How to set Physical server and logical server
I am using the Elster A220 meter. Iam using your software for the first time to read the meter reading. But for Elster meter there is Meter ID on the top of the cover.
How do i set the physical server and logic server by using MeterID?
I need your help.
Kurumi's picture
You do not need to take care of Meter ID if you are communicating using serial port
or Infrared Eye.
Just create new device and do not change physical or logical server addresses.
Everything should work like charm.
If you have problems, send you log file (from Tools menu) to me.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Hi, I can't connect to an Elster A220 meter, the log is as follows:
GXDLMSDirector 8.2.1912.0501
Log created 12:52:52
System.Exception: Invalid name.
en GXDLMSDirector.DevicePropertiesForm.UpdateSettings(GXDLMSMeter device, Boolean validate)
en GXDLMSDirector.DevicePropertiesForm.OKBtn_Click(Object sender, EventArgs e)
13:01:03 Initializing serial connection.
13:01:04 IEC Sending:/?!<CR><LF>
13:01:14 Failed to receive reply from the device in given time.
en GXDLMSDirector.GXDLMSDevice.InitializeConnection()
en GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
13:01:46 Initializing serial connection.
13:01:47 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="10" />
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
13:01:52 Data send failed. Try to resend 1/3
13:01:57 Data send failed. Try to resend 2/3
13:02:02 Failed to receive reply from the device in given time.
13:02:02 Disconnect request
13:02:02 Send Disconnect request.
7E A0 07 03 21 53 03 C7 7E
<HDLC len="9" >
<FrameType Value="53" />
<DisconnectRequest>
</DisconnectRequest>
</HDLC>
13:02:07 Data send failed. Try to resend 1/3
13:02:12 Data send failed. Try to resend 2/3
13:02:17 Failed to receive reply from the device in given time.
13:03:05 Initializing serial connection.
13:03:06 IEC Sending:/?!<CR><LF>
13:03:26 Failed to receive reply from the device in given time.
13:03:47 Initializing serial connection.
13:03:49 Send SNRM request.
<HDLC len="9" >
<Snrm>
</Snrm>
</HDLC>
13:03:59 Data send failed. Try to resend 1/3
13:04:09 Data send failed. Try to resend 2/3
13:04:19 Failed to receive reply from the device in given time.
13:04:19 Disconnect request
13:04:19 Send Disconnect request.
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
13:04:29 Data send failed. Try to resend 1/3
13:04:39 Data send failed. Try to resend 2/3
13:04:49 Failed to receive reply from the device in given time.
13:05:31 Initializing serial connection.
13:05:32 Send SNRM request.
<HDLC len="9" >
<Snrm>
</Snrm>
</HDLC>
13:05:37 Data send failed. Try to resend 1/3
13:05:42 Data send failed. Try to resend 2/3
13:05:47 Failed to receive reply from the device in given time.
13:05:47 Disconnect request
13:05:47 Send Disconnect request.
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
13:05:52 Data send failed. Try to resend 1/3
13:05:57 Data send failed. Try to resend 2/3
13:06:02 Failed to receive reply from the device in given time.
13:06:07 Initializing serial connection.
13:06:09 Send SNRM request.
<HDLC len="9" >
<Snrm>
</Snrm>
</HDLC>
13:06:14 Data send failed. Try to resend 1/3
13:06:19 Data send failed. Try to resend 2/3
13:06:24 Failed to receive reply from the device in given time.
13:06:24 Disconnect request
13:06:24 Send Disconnect request.
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
13:06:29 Data send failed. Try to resend 1/3
13:06:34 Data send failed. Try to resend 2/3
13:06:39 Failed to receive reply from the device in given time.
13:08:26 Initializing serial connection.
13:08:28 IEC Sending:/?!<CR><LF>
13:08:38 Failed to receive reply from the device in given time.
13:09:11 Initializing serial connection.
13:09:13 Send SNRM request.
<HDLC len="9" >
<Snrm>
</Snrm>
</HDLC>
13:09:18 Data send failed. Try to resend 1/3
13:09:23 Data send failed. Try to resend 2/3
13:09:28 Failed to receive reply from the device in given time.
13:09:28 Disconnect request
13:09:28 Send Disconnect request.
<HDLC len="9" >
<DisconnectRequest>
</HDLC>
13:09:33 Data send failed. Try to resend 1/3
13:09:38 Data send failed. Try to resend 2/3
13:09:43 Failed to receive reply from the device in given time.
Kurumi's picture
A220 isn't supported by DLMS. It's using EN62056-21. You can't read it with GXDLMSDirector.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
