Finally the problem were the HDLC addresses. It's neccessary to select Address Type as custom and then client and server address works correctly.
Now we have another problem, collecting objects fails. It's looks like the timeout (20 sec) was not enough. I tried to modify this value, but when I try to build the project GXDLMSDirector some files like GXGraphItemForm.cs are lost.
Connection now ok, collecting objects fail
There is the log.
10:09:20 Initializing serial connection.
10:09:20 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
10:09:20 Reveived data
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 F8 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 48 0E 7E
10:09:20 Parsing UA reply.
10:09:20 Parsing UA reply succeeded.
10:09:20 Send AARQ request
E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF
10:09:20 Reading object System.Byte[] from interface None
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 99 C8 7E
10:09:21 Reveived data
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 F4 00 07 24 4F 7E
10:09:21 Parsing AARE reply
10:09:21 Parsing AARE reply succeeded.
10:10:01 Send Keep Alive
7E A0 07 03 21 31 17 87 7E
10:10:01 Reveived data
7E A0 07 21 03 31 17 21 7E
10:10:41 Send Keep Alive
10:10:41 Reveived data
10:11:05 --- Collecting objects. ---
10:11:05 Collecting objects
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 0F 00 00 28 00 00 FF 02 00 94 9E 7E
10:11:26 Failed to receive reply from the device in given time.
7E A9 01 21 03 52 74 6A E6 E7 00 C4 02 81 00 00 00 00 01 00 81 EE 01 0F 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 58 FE 7E
Problem
We have updated the files to SVN, so you can compile GXDLMSDirector now.
What meter you are using (manufacturer and model)?
We will studdy your log file. You will heard us soon.
