By ortrat, 2 September, 2011
Hi all
I am new to the forum and am trying to learn a bit about the DLMS/COSEM protocol.
I need to communicate with a ACTARIS SL7000 meter
I'm trying to create a new manufacturer in DLMS/COSEMDirector but will not let me assign the value UINT32 in the Server Address TYPE variable.
Can you help with this question.
We verified that this is a bug. We will fix this and release new version on Monday.
There is a workaround that you can use. After you have select Server Address Type, like UINT32, select other Address Type like Serial Number. This will update value.
Server address type.
Hi: We have modified the XML
Hi:
We have modified the XML by hand and it works.
Thank you for your answer.
