I checked this from the standard and source code and it seems that you are right.
For some reason we are not send Disconnect message if IEC-62056-47is used.
I'll have to check why. There might be some reason that I can't remember now.
I check this out and give you an answer on Monday.
don't worry about the time to answer. I just get noticed about this issue and I think that could be useful for you to know about it, but I don't need the functionality right now.
I was testing the Disconnect request but my DLMS server didn't do anything. So I looked for the dialogue in the log file and I found the following frame:
16:38:32 Disconnect request
00 01 00 10 00 80
that seems the header of a request, with the version, client WPort and Server WPort, but nothing more.
Disconnect message with network connection
Hi Heitor,
Best Regards,
Hi Mikko, don't worry about
Thank you for your time.
Best regards
Heitor.
Bug fixed.
We have fixed this and released new versions and updated source code.
Hi, I was testing the
00 01 00 10 00 80
Is this the correct frame?
Best regards.
Disconnect request
No, it is not a correct frame. We will fix this ASAP and we are releasing new version later on this week.
