By meisam, 17 January, 2011
Hello
Gurux absolutely sounds great, but when I searched about Actaris meters I
found some different information about exchanging data with this manufacture
by Gurux component.
It's pleasure to know can I use Gurux component for Actaris meters
(model:ACE6000)?
If I can use what is the client id and server id for this manufacture?
thanks a lot for your attention.
with regards.
_______________________________________________________________________
Moved this thread from General Discussion.
-admin-
The best way to check, is to contact the meter manufacturer, so we sent Itron (current owner of Actaris) an inquiry about ACE6000, to find, whether it supports DLMS/COSEM protocol, and about Client ID & Server ID.
As soon as they get back to us, we'll share the information here.
We do not have ACE6000 in our office, so I'm not sure from right parameters.
We have contact to Itron several times, but they have not reply. :-(
This is sad, because several other manufacturers answered very fast.
You can try to set Client ID to 0x10 and Server ID to 1.
Please, let us know if you succeeded.
BTW: Are you using serial port or TCP/IP connection?
Awaiting information from Itron
Hi meisam, and welcome to GXForum!
Kindest regards,
MerjaS
hi all, just found a list of
hi all,
just found a list of some sort to check about compatibility of various meters and protocols at http://www.itf-edv.de, a german company of metering.
at least according to their list ACE6000 supports DLMS
Stephen
ACE 6000
