By balavelocity, 2 December, 2010 Hi, My Customer has some issues when working with your SMS software. It throws the following error at runtime. "GXSMS::Open Failed: The System cannot find the file specified." After a few seconds it says the following "Object reference not set to an instance of and object." Version of Gurux.SMS.dll is 5.1.0.26 Version of Gurux.Common.dll is 5.1.0.6 Please let me know how to solve the issue. SMS Error Hi, Error is received from Windows. It simply means that COM port is not available. If modem is in USB port, COM port might change when you reboot your Windows. Change COM port to correct one and this error go away. Happy Coding, Mikko SMS error While using the LAPtop, what property I have to change to clear the error Regards, balavelocity RE: SMS Error Hi, You have to set serial port of GXSMS component to correct one. GXSMS1.Port = "COM1" Or then you can call Properties-method and set correct serial port. GXSMS1.Properties(Null) If you are using GXSMS Sample select Properties button and set correct port. Happy Coding, Mikko Log in or register to post comments
SMS Error
Happy Coding,
SMS error
balavelocity
RE: SMS Error
Happy Coding,
