By Kurumi, 6 September, 2010
We have received lots of emails saying that communication with DLMS device is not working. All the emails are handling the same problem.
There is one catch when communicating with DLMS device. There is a message (packet) counter. Every time when a new message is sent, message counter is increased.
For this reason, after you start to communicate with DLMS component you can't create new DLMS component and use this component to communicate with same device. If you do so, message counter is not correct and device does not reply.
For the same reason, do not try to communicate with multible devices using the same component.
USE ONE COMPONENT TO COMMUNICATE WITH ONE DEVICE!
For example, when:
CGXCOSEMClass target = new CGXCOSEMClass();
//Set device settings.
//Send data and read response.
object data = target.SNRMRequest();
//CGXDLMSLimits limits = target.ParseUAResponse();
data = target.AARQRequest();
target.ParseAAREResponse(Helpers.GetBytes(UnitTest_GuruxDLMS.Resources.FailedAAREResponse));
That is fine, but do NOT do this.
data = target.GetObjects(RegisterObjectType.AssociationSn);
DLMS/COSEM VB sample
You can find DLMS/COSEM VB 6. sample from here:
http://www.gurux.fi/node/263
Happy coding,
instaling dlms component
hello
i want to use grux dlms component in vb6 how can i use it? how can i install it?
is there any example in vb6?
