  3. Clou
Clou
Profile picture for user craqdi
By craqdi , 14 July, 2026
I want to put a simulator in clou format how should it be done?
3 months 2 weeks ago
Hi, You need to read the…
You need to read the Clou meter with GXDLMSDirector. Select the meter and you can see the "Command line parameters". Set those parameters after Gurux.DLMS.Simulator.Net.exe. Something like this:
Gurux.DLMS.Simulator.Net.exe -S COM8 -o simulator_template.xml -t Verbose
See detailed instructions from here:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Simulato…
