  2. Gurux.c Testing With Gxdlmsdirector Ctt Test
gurux.c testing with gxdlmsdirector ctt test
By dlmsDeveloper, 15 November, 2025
Gurux DLMS for ANSI C
I use Gurux.c library and when i tested it with gxdlmsdirector ctt test
The Communication is ok between this two (Device and Software)
But when software was sent only this :
7e a0 2f 00 02 0e d3 03 10 5e 66 e6 e6 00 c8 1e
30 00 00 00 0c 63 a9 c6 fe 56 8e 96 a8 9f fe ed
1b c9 a9 a3 15 20 64 85 be 96 2f 07 00 c8 b8 6e
7e
1: 7E A0 2F 00 02 0E D3 03 10 5E 66 E6 E6 00 C8 1E 30 00 00 00 0C 63 A9 C6 FE 56 8E 96 A8 9F FE ED 1B C9 A9 A3 15 20 64 85 BE 96 2F 07 00 C8 B8 6E 7E
<HDLC len="2E" >
<!-- Logical address:1, Physical address:1001 -->
<TargetAddress Value="43E9" />
<SourceAddress Value="1" />
<!-- AARQ frame. -->
<FrameType Value="10" />
<PDU>
<!-- Invocation Counter: 12 -->
<!-- Decrypt data: C0 01 C1 00 0F 00 00 28 00 00 FF 01 00
<GetRequest>
<GetRequestNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
<AttributeDescriptor>
# AssociationLogicalName
<ClassId Value="000F" />
# 0.0.40.0.0.255
<InstanceId Value="0000280000FF" />
# Logical Name
<AttributeId Value="01" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
<glo_GetRequest Value="300000000C63A9C6FE568E96A89FFEED1BC9A9A315206485BE962F0700C8" />
</PDU>
</HDLC>
The device has hard-fault error
I check it, when i send it alone, without any other packet, the device is freeze, I debugged it and found this :
in Ciphering.c in gxgcm_transformBlock function at this line :
bb_set(&nonceAndCounter, systemTitle, 8);
the systemTitle is empty and the hardfault is happen
how can I fix this problem?
Thanks.
6 months 3 weeks ago
Hi, I believe that you haven…
I believe that you haven't set the system title for the meter. You need to set it.
dlmsDeveloper
Thanks for your respons I…
I Check it again
and set these as you said before :
BB_ATTACH(Settings.base.clientSystemTitle, CLIENT_SYSTEM_TITLE, 8);
BB_ATTACH(Settings.base.preEstablishedSystemTitle, SERVER_SYSTEM_TITLE, 0);
Also for securitySetup :
BB_ATTACH(SecuritySetupMgPre.serverSystemTitle, SERVER_SYSTEM_TITLE, 8);
BB_ATTACH(SecuritySetupMgPre.clientSystemTitle, CLIENT_SYSTEM_TITLE, 8);
But When I sent just this packet:
7e
It has hardfault becuase of this line :
Functions :
svr_handleRequest4
==> dlms_getData2
==> dlms_getData3
==> dlms_getPdu
==> dlms_handleGloDedRequest
in :
else if (emptySourceSystemTile){...}
when it run :
if ((ret = cip_decrypt(&settings->cipher,
#ifndef DLMS_IGNORE_MALLOC
settings->preEstablishedSystemTitle->data,
(settings->cipher.broadcast ? &settings->cipher.broadcastBlockCipherKey : &settings->cipher.blockCipherKey),
#else
settings->preEstablishedSystemTitle,
(settings->cipher.broadcast ? settings->cipher.broadcastBlockCipherKey : settings->cipher.blockCipherKey),
#endif //DLMS_IGNORE_MALLOC
& data->data,
&security,
&suite,
&invocationCounter)) != 0)
return ret;
this function :
in this line :
HardFault Error happened
Please Help me Fix it
Thank you.
6 months 2 weeks ago
Hi, Are you using the pre…
Are you using the pre-established connection? If you are, you can't use glo_GetRequest because the system title is not sent as part of the PDU.
You must set the general protection conformance for the client. When general protection conformance is set, the GeneralGloCiphering message is used.
  • Thu, 05/28/2026 - 13:16
    Gurux.DLMS.Net 9.0.2605.2801
  • Thu, 05/28/2026 - 13:14
    Gurux.DLMS.Python 1.0.198
  • Tue, 05/26/2026 - 11:37
    gurux.dlms.c 9.0.2605.2601
