  3. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd , 21 July, 2025
Gurux DLMS for Android
I am integrating Bluetooth communication using the Gurux Java library. The communication setup, including SNRM and AARQ requests, is working fine. However, the Association Request does not work with meters other than LGZ Single Phase over Bluetooth, even though it works correctly over serial communication. I verified that the Association Request sent over both serial and Bluetooth is identical, but only the Bluetooth fails to get a response. Please suggest what could be the possible issue."
7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
1 year 3 months ago
Hi, Have you established the…
Have you established the connection to the meter before reading the association view?
The meter doesn't reply if the connection is not established.
