  3. Load Profile
Load profile
By Danlew2018 , 8 July, 2025
Can someone explain in simple terms how reading load profile data works on an L+G E560 meter?
1 year 4 months ago
Hi, I'm afraid that it's not…
I'm afraid that it's not so easy.
You need to read capture objects, and then you can read the buffer using read by range/entry. Check this link.
I propose that you download GXDLMSDirector and select L+G as a manufacturer.
Then establish the connection to the meter and read it. I believe it will help you to understand DLMS meters.
